Enthusiast ![]() Joined May 27, '09 From Finland Currently Offline Reputation: 0 (0%) ![]() |
Can you tell is there big difference between JDM projectors and non-JDM (original? What you would call those
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) ![]() |
Can you tell is there big difference between JDM projectors and non-JDM (original? What you would call those ![]() Projector headlights house HID lights which generally have higher light output than halogen bulbs. Many people use HID's in non-projector lights which is dangerous and usually illegal. Also projector put out solid light with a cut-off, where as a non-projector slightly scatter the light. For example: with my old halogen style headlights with 10,000K HID's ![]() with projectors and 6000K HID's ![]() Hope this helps explain the difference a little ![]() (Note: I dont have jdm lights.. just usdm and usdm with a projector retrofit mod) This post has been edited by smkr3w: Sep 29, 2012 - 4:41 AM -------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
I had DDM 35w 4,500K HID's in my standard housings then I switched to JDM projectors and only changed from a 9006 to an H1 bulb, otherwise my setup stayed the same. I immediately noticed better light output. It's not so much that projectors put out "more light" or "better light," but as smkr3w said they control the light output better. The USDM lights scatter light output, where projectors aim the light much better and have a cutoff to prevent glare from shining too high, into oncoming traffic.
![]() Enthusiast ![]() ![]() ![]() Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) ![]() |
I have an St204 with oem Usdm headlights and an St205 with JDM projectors. Both with Halogen bulbs. Huge difference.
I don't see any farther, but I do see a lot more clearly at close range. |
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) ![]() |
Projector designs have nothing to do with HID, or halogen. They're a housing type.
Most HID systems do use projector housings. Many halogen systems use projector housings -- projectors showed up in cars in the 1960s, long before HID came into being. And notably, not all HID systems use projector housings. The problem is when people combine a housing meant for one type of system with the bulbs from another type. Typically, this means sticking an HID bulb in a halogen housing. Halogens produce significantly fewer lumens (measure of light output), but it's the beam design that's the real mismatch. Headlight housings focus the light output of the bulb; change the location, size, or orientation of the light source and you change where the light ends up. You can't properly aim a halogen housing when using an HID bulb. Projectors are the most efficient type of headlight housing, as they let the most light through. Least efficient are parabolic reflectors, as they require fairly thick front lenses to focus the light. Complex reflectors are the middle child, using a clear front lens and multi-faceted interior which some people refer to as crystal-clear headlights. Projectors do indeed put out more light than a parabolic or complex reflector of equal quality. Beam pattern is an entirely separate issue. You can get the same level of control out of a complex or parabolic housing as you can from a projector, but manufacturers who are willing to spend extra to get the efficiency of a projector housing are unlikely to accept a poor beam pattern. Parabolic and complex reflectors being cheaper to manufacture are more likely to be subject to poor design. The shape of the headlight's output is determined by law. The US standard is the DOT standard, which stems from the 1950s when overhead signs weren't illuminated. The DOT thus calls for a beam pattern where about half the light is thrown upwards, while the rest lands on the road in two distinct hotspots. This is true of U.S. projector housings as well. Pretty much the rest of the developed world expects overhead signs to be illuminated, so the beam pattern calls for the light to be spread evenly below a flat cutoff, with a tick upwards to illuminate roadside signs, somewhat like this: _____/. This is known in North America as ECE or E-code. The difference is design is why the US didn't get the HID systems for years after the rest of the world did, since putting half the light of an HID system into an oncoming driver's eyes is a bad idea. It is equally illegal to put an HID bulb in a halogen projector as it is to put an HID bulb in a halogen parabolic reflector. And for that matter, it would be illegal to put a halogen bulb in the complex reflector housing of a Nissan Altima 2.5 SE, as that complex reflector uses HID bulbs. Sticking an HID bulb into a halogen housing, or vice versa, meant for DOT standards produces a misaimed beam pattern with blinding glare. Projectors were the primary housing choice for HID systems because they emphasized the performance difference between halogen and HID, and because projectors and HID are premium features which add cachet to luxury cars (similar to leather-wrapped and heated steering wheels, each is a feature but combined they spell luxury). The JDM -- and for that matter, European -- headlights on sixth-gen Celicas used projectors with halogen bulbs. The H in the bulb designation tells you this. Since the sixth-gen can accommodate projector housings, the best choice is to buy projectors meant for HID bulbs, with the ECE beam pattern. This gives you correctly matched housings and bulbs with the efficiency of a projector housing and the output of HID. |
Lo-Fi Version | Time is now: April 23rd, 2025 - 5:47 PM |
