How to deglaze rotors |
Oct 9, 2012 - 10:47 PM |
Enthusiast Joined Sep 30, '11 From Sydney Currently Offline Reputation: 0 (0%) |
Hi guys,
Went to the track the other day and left my race pads at home. So used the normal street pads. They got WAY too hot and the rotors are horribly glazed. Lots of brown pants moments when the pedal is down but nothing happens. It was suggested by a friend that i take the rotors off and use a cup brush(wire brush on an angle grinder) to remove it then use fine grades of sand paper to smooth it out and of course rub the pads on concrete. Wanting to know if anyone can comment on this method and/or propose a different one? Thanks, Reece |
Oct 9, 2012 - 11:02 PM |
Enthusiast Joined Mar 1, '10 From TX Currently Offline Reputation: 16 (90%) |
Hi guys, Went to the track the other day and left my race pads at home. So used the normal street pads. They got WAY too hot and the rotors are horribly glazed. Lots of brown pants moments when the pedal is down but nothing happens. It was suggested by a friend that i take the rotors off and use a cup brush(wire brush on an angle grinder) to remove it then use fine grades of sand paper to smooth it out and of course rub the pads on concrete. Wanting to know if anyone can comment on this method and/or propose a different one? Thanks, Reece i imagine a really fine sand paper and a block would do the trick not sure what it like there but here the BAp/geaon (kinda like an autozone) will resurface your rotor for 9 bucks -------------------- JN 3:16
Oct 9, 2012 - 11:25 PM |
I'd like to say otherwise but you'll probably need to resurface them.
You should have a set of rotors for the track pads... the material isn't the same as a normal pad and pads "bed in" into the rotors (transfer friction material onto them) and most of the time track pads and street pads don't have compatible materials. -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Oct 10, 2012 - 12:36 AM |
O'Reilly's used to do free resurfacing, not sure if they do anymore.
Oct 10, 2012 - 8:04 AM |
Oct 10, 2012 - 9:03 PM |
Thanks guys.
We have auto stores here sorta like autozone from what i can gather and my local one charges 30/rotor to resurface and havent found much cheaper. So i guess ill give it a go and if all else fails ill prob just buy new rotors |
Oct 10, 2012 - 9:30 PM |
use 80grit sand paper and sand the rotors perpendicular to the rotation. And sand the brake pads. Basically you want your rotors to have a Matte finish. Go easy on the rotors once installed for the next couple of miles to allow the pads to reseat.
If your still have glazing issues on the rotors, it means your not have sufficient cooling of the rotors. You may need to upgrade your rotors and pads to be more compatible with each other. |
Oct 11, 2012 - 11:19 PM |
Thanks, keep the ideas coming if possible
Oct 14, 2012 - 7:14 PM |
Enthusiast Joined Feb 8, '10 From North Carolina Currently Offline Reputation: 0 (0%) |
I wouldnt keep switching out pads and rotors just for the track. Like mentioned before, pads have to set into the rotor, every time you take them off they are going to need to be seated once again. Normally 45mph med. pedal pressure to a stop a couple times will seat them. Id look and see if you cant find some high end rotors, get whatever pads you wanna run and leave them on.
Oct 16, 2012 - 2:21 PM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
Take some sandpaper to the pads, the rotors should be resurfaced, which, depending on what kind of rotors you're using, it may be be cheaper/same price to just buy new rotors.
-------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Oct 16, 2012 - 7:02 PM |
Currently still has the original rotors, want to try use them till they are in dire need of replacing. Every time I swap pads I do reseat them however painful it is. Starting to think it might be a good idea to just use the race pads all the time and screw the daily ones.
Oct 17, 2012 - 9:00 AM |
Currently still has the original rotors, want to try use them till they are in dire need of replacing. Every time I swap pads I do reseat them however painful it is. Starting to think it might be a good idea to just use the race pads all the time and screw the daily ones. I think thatll be best. Measure the rotor thickness aswell. Make sure your within spec. If you need the spec i can find it for you. If you dont have enough material your rotor will become too hot. |
Oct 17, 2012 - 11:21 AM |
Currently still has the original rotors, want to try use them till they are in dire need of replacing. Every time I swap pads I do reseat them however painful it is. Starting to think it might be a good idea to just use the race pads all the time and screw the daily ones. you could get a set of "race rotors" and change them out when you swap out the pads so that way you don't have to reseat them everytime -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Oct 17, 2012 - 9:07 PM |
Currently still has the original rotors, want to try use them till they are in dire need of replacing. Every time I swap pads I do reseat them however painful it is. Starting to think it might be a good idea to just use the race pads all the time and screw the daily ones. you could get a set of "race rotors" and change them out when you swap out the pads so that way you don't have to reseat them everytime anytime pads are removed they have to be reseated. |
Oct 18, 2012 - 1:56 PM |
Currently still has the original rotors, want to try use them till they are in dire need of replacing. Every time I swap pads I do reseat them however painful it is. Starting to think it might be a good idea to just use the race pads all the time and screw the daily ones. you could get a set of "race rotors" and change them out when you swap out the pads so that way you don't have to reseat them everytime anytime pads are removed they have to be reseated. How so? I thought you were referring to breaking in pads by getting a thin film of pad on the surface of the rotor which, if you only use pads "A" with rotors "A" and pads "B" with rotors "B" you won't need to do this everytime because the pads will already be broken in for the rotors you're using. -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Oct 19, 2012 - 7:41 AM |
[/quote]
How so? I thought you were referring to breaking in pads by getting a thin film of pad on the surface of the rotor which, if you only use pads "A" with rotors "A" and pads "B" with rotors "B" you won't need to do this everytime because the pads will already be broken in for the rotors you're using. [/quote] I thought this also. @celica74 if you have the rotor specs lying around that would be awesome! |
Oct 19, 2012 - 11:22 AM |
QUOTE How so? I thought you were referring to breaking in pads by getting a thin film of pad on the surface of the rotor which, if you only use pads "A" with rotors "A" and pads "B" with rotors "B" you won't need to do this everytime because the pads will already be broken in for the rotors you're using. I thought this also. @celica74 if you have the rotor specs lying around that would be awesome! Yup, Ive swapped rotors and pads from another car before, just make sure they are installed EXACTLY the same. If you think about it, when you remove the caliper or rotor to do any repair work(struts, axles, clutch) you are "unseating" the pads but they will realign themselves the first time you hit the brakes applying thousands of pounds of torque and compression. |
Oct 19, 2012 - 7:08 PM |
@celica74 if you have the rotor specs lying around that would be awesome! I've got them: 1994-97 Celica 1.8L Front: Runout limit .0019; Nominal Thickness .984; Discard .906 1994-99 Celica 2.2L Front: Runout limit .0019; Nominal Thickness 1.102; Discard 1.024 1994-95 Celica All Rear: Runout limit .0059; Nominal Thickness .394; Discard .354 1996-99 Celica All Rear: Runout limit .0059; Nominal Thickness .354; Discard .315 -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Oct 20, 2012 - 3:40 AM |
Thanks, I'll have to measure mine now. Also still haven't gotten the time to try deglaze them but will report back when I have done so
Oct 20, 2012 - 8:49 AM |
Currently still has the original rotors, want to try use them till they are in dire need of replacing. Every time I swap pads I do reseat them however painful it is. Starting to think it might be a good idea to just use the race pads all the time and screw the daily ones. you could get a set of "race rotors" and change them out when you swap out the pads so that way you don't have to reseat them everytime anytime pads are removed they have to be reseated. How so? I thought you were referring to breaking in pads by getting a thin film of pad on the surface of the rotor which, if you only use pads "A" with rotors "A" and pads "B" with rotors "B" you won't need to do this everytime because the pads will already be broken in for the rotors you're using. The pad will never sit in the same place everytime. Even if you just lift the caliper up and put the pads right back. Still have to seat them. |
Lo-Fi Version | Time is now: November 26th, 2024 - 1:46 AM |
