Lightened Flywheel applications |
Oct 15, 2012 - 3:55 PM |
Enthusiast Joined Aug 5, '10 From WOODHAVEN NY Currently Offline Reputation: 0 (0%) |
Hi all,
I am looking for a lightened flywheel application for my 1997 celica ST 1.8L 7AFE I have to replace the clutch so I would like to upgrade the whole thing can anyone confirm which flywheels fit please thanks |
Oct 15, 2012 - 4:07 PM |
southbend! www.dxdracingclutches.com give them a call and talk to Andy in the import dept. tell him what you have and that i sent you. you want a fidanza flywheel and TZ clutch. they look like these
old on the left -------------------- 2001 Celica GT-S Turbo
Oct 15, 2012 - 4:14 PM |
I do not see the application on the website but I will give Andy a call thanks alot I appreciate it.
Oct 16, 2012 - 12:20 PM |
yes call him, he will help you out. if he isnt there talk to John
Oct 16, 2012 - 12:58 PM |
I gave them a call great price for the clutch kit I spoke to dave john is on vacation and andy is not in today the have flywheels in stock but he is not sure which one will fit either they have for the 1zz and 2zz
Oct 16, 2012 - 1:48 PM |
Enthusiast Joined Mar 15, '12 From Wrightstown, NJ Currently Offline Reputation: 6 (100%) |
If you need to get your car back on the road quickly, I would have to recommend just getting an OEM 7afe flywheel. It will cost you probably $50-$70 depending on where you get it. A lightweight flywheel will cost you significantly more, and I wouldn't even know where to find one. It's all a matter of prioritizing here. A stock flywheel will get you back on the road the fastest.
-------------------- 1989 Celica ST Automatic "King Cobra" -- 2005-2006
1994 Celica ST 5-speed "King Cobra II" -- 2011-???? |
Oct 16, 2012 - 2:06 PM |
you are right I just figured if i have to pull down the whole trans. I might as well upgrade the flywheel as well as the clutch.
Oct 16, 2012 - 2:18 PM |
you are right I just figured if i have to pull down the whole trans. I might as well upgrade the flywheel as well as the clutch. If I remember what Smaay said from some past thread, the clutch and pressure plates for the 1zz and 2zz will work with the stock 7afe flywheel - which is to say, everything lines up for mounting the pressure plate to the flywheel. I assume he also meant that the clutch disc itself mounts perfectly onto your C52 transmission's input shaft (appropriate diameter and number of splines) but I would DEFINITELY clarify that last bit before ending up with something which may be the wrong size. -------------------- 1989 Celica ST Automatic "King Cobra" -- 2005-2006
Oct 16, 2012 - 2:30 PM |
yeah thats what i am working on now and getting no where.
Oct 17, 2012 - 12:49 AM |
yes the 2ZZ clutch pressure plate and disk are compatable with the 7A transmission and they bolt to the stock flywheel. Im just nor sure about the fidanza part.
Oct 17, 2012 - 8:15 AM |
http://www.6gc.net/forums/index.php?showtopic=83759
Pretty sure he's using a 4age flywheel -------------------- 95 gt coupe, v6 swap weekend toy
Oct 17, 2012 - 2:42 PM |
Enthusiast Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
Oct 17, 2012 - 3:05 PM |
the C60 is the 6 speed that comes on the GT-S the C54 is the 5 speed on the 1ZZ GT.
the splines are the same. a 1ZZ/2ZZ clutch DISK will work on your 7A transmission. I have personally done this in Erynns car. -------------------- 2001 Celica GT-S Turbo
Oct 18, 2012 - 12:23 AM |
If you need to get your car back on the road quickly, I would have to recommend just getting an OEM 7afe flywheel. It will cost you probably $50-$70 depending on where you get it. A lightweight flywheel will cost you significantly more, and I wouldn't even know where to find one. It's all a matter of prioritizing here. A stock flywheel will get you back on the road the fastest. ?? Not the advice he was looking for, and I'm wondering why you would suggest buying again what he already has? it just needs to be resurfaced... my st205 is on its 4th clutch with the original flywheel machined every time, the only thing i would recommend is buying some new ARP flywheel bolts on every 2nd clutch job -------------------- Mike W
Oct 18, 2012 - 1:09 AM |
If you need to get your car back on the road quickly, I would have to recommend just getting an OEM 7afe flywheel. It will cost you probably $50-$70 depending on where you get it. A lightweight flywheel will cost you significantly more, and I wouldn't even know where to find one. It's all a matter of prioritizing here. A stock flywheel will get you back on the road the fastest. ?? Not the advice he was looking for, and I'm wondering why you would suggest buying again what he already has? it just needs to be resurfaced... my st205 is on its 4th clutch with the original flywheel machined every time, the only thing i would recommend is buying some new ARP flywheel bolts on every 2nd clutch job Sometimes there aren't any machine shops that can re-surface flywheels and other times it costs just as much as a new flywheel |
Oct 18, 2012 - 11:45 AM |
That makes no sense to me either, clutch&brake&transmission shops are just as important as mechanical workshops and autoparts stores
over here shops even advertise free machining as a way to lure you into buying your clutch from them... -------------------- Mike W
Oct 18, 2012 - 8:53 PM |
If you need to get your car back on the road quickly, I would have to recommend just getting an OEM 7afe flywheel. It will cost you probably $50-$70 depending on where you get it. A lightweight flywheel will cost you significantly more, and I wouldn't even know where to find one. It's all a matter of prioritizing here. A stock flywheel will get you back on the road the fastest. ?? Not the advice he was looking for, and I'm wondering why you would suggest buying again what he already has? it just needs to be resurfaced... my st205 is on its 4th clutch with the original flywheel machined every time, the only thing i would recommend is buying some new ARP flywheel bolts on every 2nd clutch job Heh, since he was talking about getting a lightweight flywheel, I was thinking in terms of "getting a flywheel". Not exactly hard to read "Just go OEM if you really need it soon" out of that. Also: 4A-FE Lightweight Flywheel. It is the 212mm diameter variety (I think the previous generation of 4A-FE and 7A-FE used a 200mm diameter). It has the 6-bolt crank pattern common to the 4A-C, 4A-FE and 7A-FE. 4A-GE flywheels are all 8-bolt, and won't work for this application. 1ZZ and 2ZZ flywheels are also 8-bolt as far as I know. -------------------- 1989 Celica ST Automatic "King Cobra" -- 2005-2006
Oct 19, 2012 - 2:23 PM |
I understand that there is a lot more engineering that goes into making a flywheel light, which is why they're so expensive, but I don't understand why the difference is so large. A new, OEM-spec flywheel can be had for $50.
'93 MX-5 LE |
Oct 24, 2012 - 2:45 PM |
C56 in 1zz engines n C52 on 7afe
Nov 8, 2012 - 10:07 AM |
well i can now tell you that the Fidanza flywheel from a 7th gen will not work on a 7A-FE. the 1ZZ/2ZZ uses an 8 bolt flywheel and the 7A has a 6 bolt flywheel
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:18 AM |
