Enthusiast ![]() Joined Aug 5, '10 From WOODHAVEN NY Currently Offline Reputation: 0 (0%) ![]() |
does anyone know which is the Fidanza Flywheel that will fit the ST 1.8L 7AFE Celica maybe a part number perhaps I found one not a 100% sure if it will fit however I've seen someone say that i believe the 1zz or the 2zz are the same fit can someone confirm?
http://www.ebay.com/itm/120310423057?ssPag...984.m1438.l2649 will this fit? |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
the 1ZZ and 2ZZ clutch is the same. I can NOT confirm that the flywheel is the same because the 1ZZ and 2ZZ do NOT share the same flywheel. now it is possible that the 1ZZ flywheel is the same as the 7A-FE
Enthusiast ![]() ![]() ![]() Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) ![]() |
7AFE Flywheel (Toyota) Part #: 13405‑15090
1ZZFE Flywheel (Toyota) Part #: 13451‑22020 So to answer your question, no they don't fit. But if you would have searched and maybe tried a little bit you would have known that...took me all of 1 minute on toyodiy.com Also theirs no need to post a million threads, you can always edit your thread or just post another question in it... This post has been edited by travisxcore: Oct 16, 2012 - 1:50 PM |
you know what you are right I should have not posted so many threads I just need answers as soon as possible and you are right about the part numbers the only problem is thats oem not aftermarket that I knew no where shows the lightened flywheel for my car but I have heard it has been done with a flywheel from another celica which fits like a direct replacement therefore I am asking to see if anyone can help me out
I'll help you out a little bit more then
![]() Okay so 7AFE & 4AFE share same parts # for flywheel, so their the same. Pretty sure I seen the 4AFE is 200mm and since they share the same flywheel itd be the same. So you need a 200mm 6 bolt pattern flywheel. Call the number on the listing and see if they can tell you I guess would be the next step. This post has been edited by travisxcore: Oct 16, 2012 - 2:14 PM |
great thanks I going to look into that right now
Sorry to be the bearer of bad news after getting your hopes up but it won't work. I forgot newer Toyotas have 21 splines, compared to older Toyotas 20 splines. Also the 1ZZ has a 210mm diameter.
This post has been edited by travisxcore: Oct 16, 2012 - 2:23 PM |
damn ok thanks for your help
Lo-Fi Version | Time is now: February 17th, 2025 - 12:19 AM |
