> 2 bar sensor, other sensor
post Oct 20, 2012 - 11:37 PM
timdog1720
Joined Mar 4, '10
From Bronx NY
Question for my st215 caldina engine can i use any 2 bar turbo map sensor to run the engine
for example would this work http://www.ebay.com/itm/GM-2-BAR-MAP-SENSO...ff6&vxp=mtr
and just rewire to the harness
what other options do I have?
Always fast and going for the look......
post Oct 21, 2012 - 11:48 AM
timdog1720
Joined Mar 4, '10
From Bronx NY
QUOTE (timdog1720 @ Oct 21, 2012 - 12:37 AM) *
bump
post Oct 21, 2012 - 10:56 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
you dont have any other options unless you had the original one to compare voltage outputs with
maybe you had many different map sensors hooked up to an air compressor with 2 bar in the line, and say.... miraculously... they all read 5 volts evenly..... (which they wont)
... then if you were to drop the pressure to 1bar.... perhaps one voltage output may drop to around 4v, another could drop to 3.7v, 3.8v, 3.9v, 4.1v, 4.2v, etc, who knows
Mike W
269awhp / 273ft-lbs
post Oct 22, 2012 - 12:53 AM
timdog1720
Joined Mar 4, '10
From Bronx NY
Ok I understand
Lo-Fi Version Time is now: November 26th, 2024 - 11:28 AM
