> Weird transmission issues on a '95 Celica AT (possibly electrical)
post Oct 25, 2012 - 10:08 PM
deadwolfbones
Joined Nov 17, '10
From Santa Fe, NM
Today I was driving home from work on the interstate at 75mph and suddenly the Overdrive Off light came on my dash, then it disappeared, then it came on again, and it kept flicking back and forth like that (with resulting gear shifts/RPM changes) until I manually pressed the toggle off and on again (probably 4-5 on/off cycles). After I manually toggled the switch, it stopped doing it for the remainder of the drive.
Any idea what might have caused this, whether it's a symptom of a larger problem, or what it might cost to fix if a cost is necessary?
The car is running perfectly otherwise, btw.
This post has been edited by deadwolfbones: Nov 13, 2012 - 11:16 PM
post Oct 26, 2012 - 1:29 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
thats an indicator that its time to get rid of an auto and get a 5 speed.
just kidding, i wish i could answer your question but instead im just going to clutter up your thread.
its possible that the ECU is seeing a short in the connection between the OD button. the button itself could be failing. the transmission might need servicing.
This is why i dont do autos
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Oct 26, 2012 - 4:43 PM
zfjohnson07
Joined Apr 11, '09
Did u check ur over drive oil?
post Oct 26, 2012 - 6:03 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Overdrive shift Solenoid?
post Oct 26, 2012 - 11:32 PM
deadwolfbones
Joined Nov 17, '10
From Santa Fe, NM
Update: commuted to/from work again on the interstate today without any issues. Weird.
post Oct 27, 2012 - 6:52 PM
zfjohnson07
Joined Apr 11, '09
look under the shifter it might be coming loose.
post Oct 27, 2012 - 7:33 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Overdrive engages only when the transmission is up to the necessary temperature, and engine RPMs are high enough. When the overdrive is flipping on and off, your first suspect is the overdrive solenoid or speed sensor.
post Nov 13, 2012 - 11:14 PM
deadwolfbones
Joined Nov 17, '10
From Santa Fe, NM
New update. Car did another weird thing today.
I was in stop & go traffic on the interstate forever, basically, and after a while I noticed it was having a hard time getting going again after traffic had come to a stop. Eventually realized it was staying in 2nd gear and not shifting down to 1st.
I drove like that the rest of the way home. Once I got home, I put it in park, then back in drive, and it was still launching in 2nd. I put it in 1st manually and it behaved as it normally would in 1st gear. Back to Drive... still tried to launch in 2nd.
So I turned the car off, started it back up, put it in drive... 1st gear, totally normal. I took it out for a quick drive and it never repeated the odd behavior.
I figure there's some kind of weird electrical glitch going on, but I have a feeling it's still gonna cost me big bucks, even if it isn't mechanical.
post Nov 14, 2012 - 3:06 AM
trdproven
Joined Aug 2, '05
From Guam
I suggest pulling the tranny error codes. That's your first step. This time u count the o/d blinks for tranny.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Nov 14, 2012 - 6:25 PM
deadwolfbones
Joined Nov 17, '10
From Santa Fe, NM
QUOTE (trdproven @ Nov 14, 2012 - 4:06 AM) *
Yeah, definitely will do.
In the meantime I drove it to and from work today and it performed totally normally. kindasad.gif
Lo-Fi Version Time is now: November 26th, 2024 - 3:35 AM
