How to replace control arm? |
Oct 31, 2012 - 12:53 PM |
Enthusiast Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) |
I need to replace or fix a control arm. The bolt parallel to the floor is loose, it's not tightening or lossenin enought to pull out
It's just free in there. Need help To me it seems like there's a nut holding the bolt from behind, but the problem is I can't see or reach back there. Is there some trick or something I'm missing? -------------------- For Sale:OEM tail lights - make offer
Oct 31, 2012 - 2:15 PM |
Sounds like you have EXACTLY the same problem I had... I had to make frantic phone calls to figure it out. You better get a torch out or a big drill bit.
There's a nut welded inside the subframe. When I tried removing that bolt, the welds on the nut broke loose. I had to cut a very ugly hole in my subframe and put an end wrench and half a can of PB Blaster on the nut to get the bolt out. I replaced the OEM nut and bolt completely, but forgot to make a plate and get the hole covered back up... Still need to do that. This post has been edited by richee3: Oct 31, 2012 - 5:04 PM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Oct 31, 2012 - 4:53 PM |
Enthusiast Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) |
Definatly a loose nut inside the frame. Had that too. Only way to fix is as richee said. Make a hole in the frame and weld the nut. Dont forget to close the hole when finished
-------------------- JDM ST205
Oct 31, 2012 - 6:29 PM |
How can I cut it? I don't have any special tools, what should I be buying?
Oct 31, 2012 - 10:07 PM |
Enthusiast Joined Oct 23, '08 Currently Offline Reputation: 24 (100%) |
use a hole saw and a drill it will make a clean hole that will be easier to patch.
Oct 31, 2012 - 10:27 PM |
use a hole saw and a drill it will make a clean hole that will be easier to patch. is hatching necessary? and will i HAVE to weld the nut back? or can i just tighten the s**t out of it? -------------------- For Sale:OEM tail lights - make offer
Nov 1, 2012 - 1:25 AM |
I would weld the nut for sure. You dont want to open up the frame everytime.
Nov 1, 2012 - 1:51 AM |
I would weld the nut for sure. You dont want to open up the frame everytime. Well then going to a shop is necessary I guess, don't have welding experience and/or tools -------------------- For Sale:OEM tail lights - make offer
Nov 5, 2012 - 9:03 PM |
You could try your luck with an impact gun. You can put on and take off endlink nuts with them (which "require" a hex key to keep the stud from spinning).
-------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Nov 6, 2012 - 10:20 PM |
You could try your luck with an impact gun. You can put on and take off endlink nuts with them (which "require" a hex key to keep the stud from spinning). why the endlinks? i was actually thinking of replacing the complete crossmember thing(which everything is bolted on to) i think thats what its called,. or the subframe, i think crossmemeber is where the engine mounts are rite ? yea i suck at identifying things with the correct terms/names -------------------- For Sale:OEM tail lights - make offer
Nov 7, 2012 - 2:18 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Had the same issue on mine too.
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Nov 8, 2012 - 4:06 PM |
Replacing the subframe is maybe the easiest way but also very timeconsuming. Just cut a hole in the old frame and weld the nut. Close the hole and you'll be fine. If you got the tools, it shouldnt take more then an hour (or 2). Replacing the frame could easily take all day.
Nov 8, 2012 - 5:26 PM |
You could try your luck with an impact gun. You can put on and take off endlink nuts with them (which "require" a hex key to keep the stud from spinning). why the endlinks? i was actually thinking of replacing the complete crossmember thing(which everything is bolted on to) i think thats what its called,. or the subframe, i think crossmemeber is where the engine mounts are rite ? yea i suck at identifying things with the correct terms/names I'm not saying to remove the endlinks, just using them as an example of things that would normally keep spinning if you tried to take them off the wrong way. -------------------- 1993 Celica GT Coupe - sold
Lo-Fi Version | Time is now: November 26th, 2024 - 8:41 AM |
