Enthusiast ![]() Joined Mar 15, '10 From Russia Currently Offline Reputation: 0 (0%) ![]() |
I know that HKS filter no good
![]() Apexi-good! I now have handmade intake adapter made of 3 "(76mm) pipe. Inner diameter unfortunately not measured it, but I think somewhere 72-73 With my adapter works well, but it's only temporary |
Put spoiler SS3
![]() ![]() Cooling panel-handmade ![]() ![]() |
The next thing I did is a tachometer.
7A-FE on the signal coming from the ECU on the other. IG-12 V E-land IG + 7V, it is a signal to the brain, the signal pulse. On all coil motors must be so!. Tramblernom on the motor, this contact is 12 volts. To tachometer earned must be removed and the device itself jumper resistor. We look at the board on the back side, where the track. The tachometer is mounted and connected to the three-pin bolts. They are signed: IG - plus at ignition, E - earth, IG-signal from ECU. Old signal from the switch was 12 volts, with a new ECU 7.5 volts. Remove the tachometer and look at the upper contact IG-, it goes through a "waste" we crossed chip resistor. That is what is what we want to close the bridge! Putting it back and lo earn! LEFT-TAHO BEAMS RIGHT-TAHO FE ![]() |
Celica meeting
![]() ![]() ![]() ![]() ![]() These photos can be seen. Are already restyled headlights |
He graduated from the swap. Now, it was decided to bring the car up to the ideal.
I'll start with the suspension. Were purchased Kyaba AGX adjustable shock FRONT-4 severity level REAR- 8severity level ![]() ![]() ![]() You must see part number ![]() ![]() for rebuild ![]() ![]() ![]() It is analog TRD. wheel bearings Quinton Hazell QWB 766 ![]() ball-bearing Jakoparts J486024 ![]() stabilizer ![]() drive shaft bearing-bearing ![]() rings for drive shafts ![]() ![]() FRONT engine bracket 12361-74400 ![]() REAR engine bracket 12371-74411 ![]() New hood C-ONE ST205 ![]() |
Recently began to notice that the carpet is not laundered after washing and wet. It was decided to open all and look.
It flowed radiator heater of salon, and more specifically the tube is in place the joint. ![]() ![]() ![]() проклеил все щели, старый поролон выкинул Beam and brackets torpedoes were in a small corrosion...strange why with plant it not painted? ![]() My work place ![]() ![]() place of mess tin ![]() ![]() chek tube) ![]() Alloy passed exactly 50km, then antifreeze began to evaporate on the glass((( it was Decided to make out again, imagine what a pleasure is to remove/put torpedo ![]() ![]() ![]() ![]() This post has been edited by Lexa666: Nov 12, 2012 - 4:26 AM |
polyurethane in the front suspension. Production Of Russia
![]() Transmission flush, decided to remove it. Also make out the pendant one ![]() ![]() The non-replaceable parts suspension decided to just paint for better appearance. Mopping-up, priming, paint, varnish ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() the exhaust pipe was jammed. Made repairs ![]() ![]() ![]() ![]() |
Mandriva to the press - HANDMADE
...FOR POLYURETANE ![]() ![]() ![]() polyuretan IN! ![]() Painted) ![]() ![]() ![]() guide sleeves ![]() ![]() ![]() Hubs were in ужастном condition. Had to clean up the metal. So I media bearings ![]() ![]() ![]() This post has been edited by Lexa666: Jan 28, 2013 - 3:57 PM |
Cleaning of the collector and the windings of the thermal tape
![]() ![]() ![]() Painted) ![]() Crearing ![]() anticorrosive processing ![]() Left drive S54 top, S53 the bottom. The difference in the length of the палок9около 3cm) the Drive is fully drunk, painted) ![]() Right-hand drive I gathered from two(right and left). The fact that the right drive shaft consists of two parts so right axis-this is the left drive!!! Stick to the length of the same! I did the following: he took a right-hand drive shaft with dead external grenade and killed right floor осью. Buying separately left drive shaft with the internal grenade. And put it all. So get the right drive shaft assy Front! grenades are the same, too(right and left) |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) ![]() |
whoa. big update. The front subframe is so clean!!
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Everything looks great so far!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) ![]() |
Wow thats nearly impossible to think kyb agx are available for St202 how much are they where did u get them from. How do you adjust the fronts?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
![]() ![]() *tags @Rusty, @S8S8, @Bonzai, etc* ![]() -------------------- Mike W
Fantastic job indeed, well done.
'93 MX-5 LE |
is that a tanabe front sway bar??? I'd say paint the whole car the color that you painted the engine bay that blue is sweet.
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
looks good so far
![]() really loving the black exhaust wrap -------------------- |
Wow thats nearly impossible to think kyb agx are available for St202 how much are they where did u get them from. How do you adjust the fronts? KYB AGX bought in Moscow. Price for 4 shock absorber about$530. Front driven shock are regulated under the hood, on the shaft of the 4 options rigidity, as the TRD. ![]() This post has been edited by Lexa666: Dec 10, 2012 - 12:38 AM |
Continue...
New silent blocks in the levers. Polyurethane. And all painted))) ![]() and I buing new body kit original in Japan ![]() ![]() ![]() Brake hoods very badly rusted, hands are not clean. Put them in the acid))) ![]() HDK not оригинал.Ring ABS no. Remove unnecessary us standard ring ![]() Remove several of ABS with the other and put in the new ![]() ![]() Brake caliper laundered, put the new gum and painted ![]() New springs ![]() ![]() ![]() Left stock-right Tein ![]() ![]() Rear brakes are also completely new, pads hammer, rotors, key pads, caliper were rebuild, washed and painted. AGX+Tein ![]() To be contunue... |
Lo-Fi Version | Time is now: February 18th, 2025 - 12:45 PM |
