> Need a radiator, Need a radiator
post Nov 7, 2012 - 2:52 PM
Bigblock
Joined Feb 14, '09
From Mid West
Need radiator ASAP so what do you think??
Murray or Spectra Premium?
About a dollar difference. Either rad will take 2 days to arrive.
post Nov 7, 2012 - 3:20 PM
czwalga
Joined Sep 27, '10
From pittsburgh
Godspeed on ebay.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Nov 7, 2012 - 3:21 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
this guy is selling a new mishimoto
http://www.6gc.net/forums/index.php?showtopic=87977
エキサイティングカーレーシングチーム!
post Nov 7, 2012 - 5:01 PM
Xander_X
Joined Apr 22, '12
From Central NY
Megan Racing
99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo
2010 Acura RDX Turbo w/ Technology Package
68 Impala SS Convertable
post Nov 7, 2012 - 5:06 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Don't get a Godspeed Rob. Mine only lasted a year before the end tanks were pissing coolant out all over the place.
Go to NAPA. They have a two core OEM replacement that comes with a lifetime warranty.
~bloodMoney
post Nov 7, 2012 - 5:31 PM
Bigblock
Joined Feb 14, '09
From Mid West
Just need stock because NOT RACECAR!! LOL!!
Checking NAPA now.
Thanks blood!!
( edit )
NAPA had 1 left in stock in Chitown. Having it delivered to store, picking it up tomorrow evening : )
This post has been edited by Bigblock: Nov 7, 2012 - 5:42 PM
post Nov 7, 2012 - 5:42 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (Bigblock @ Nov 7, 2012 - 5:31 PM) *
Checking NAPA now.
Thanks blood!!
Autozone takes two days, maybe it was $135
MAke sure to get the right one, lower hose is on the driver-side of the ST and passenger-side of the GT.
post Nov 7, 2012 - 5:47 PM
Bigblock
Joined Feb 14, '09
From Mid West
Thanks gore the tip special!! Will check b4 I commit!!
post Nov 7, 2012 - 6:41 PM
zfjohnson07
Joined Apr 11, '09
ive gotten the murray, i prefer oreileys for radiators.
post Nov 9, 2012 - 3:37 PM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (bloodMoney @ Nov 7, 2012 - 5:06 PM) *
Where at? My radiator has been through hell and still fine. I've been damn impressed with. When i rolled the entire front of the nose was pushed down the radiator moved about 3 inches and wedge between the exhaust and front frame; still no leaks.
-10 F150
post Nov 12, 2012 - 1:58 PM
Dulesgt4
Joined Nov 12, '12
From birmingham
Ive got most parts available for celicas mainly 2.0 3sge and 1.8 7afe email anytime on dules@me.com can post worldwide also if can whatapp me on 07969018590 based in birmingham uk
post Nov 12, 2012 - 6:57 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
QUOTE (czwalga @ Nov 9, 2012 - 3:37 PM) *
Did you have issues with the fan switch not threading in right?
post Nov 13, 2012 - 5:09 PM
Bigblock
Joined Feb 14, '09
From Mid West
Update--
Been running for about 30 mins now. Couple of burps from radiator, topped it off. Rev motor, fluid rises then goes down.
Q-- upper hose is warm to touch, lower is cold. Is this an issue or possible more air to burp??
This post has been edited by Bigblock: Nov 13, 2012 - 5:09 PM
post Nov 13, 2012 - 11:26 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Not completely bled yet. The lower hose will warm up when the thermostat opens up.
Was the heat on full during the bleed?
~bloodMoney
post Nov 14, 2012 - 3:13 AM
trdproven
Joined Aug 2, '05
From Guam
First u have to bleed it well. Then u can figure out after if your done or now need to check on the thermastat. Assuming you've bled it right. The lower should be hot as well. If cold still u need to take a better look at your thermastat. But when u bleed make sure its best u get your front at its highest point. Put heater in hot. And burp it. If the bubbles never stop u got a headgasket problem but I don't think u had that problem before so start with proper bleeding then the rest.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Nov 16, 2012 - 1:55 PM
Bigblock
Joined Feb 14, '09
From Mid West
Heater was on high, as was the blower fan. I had the front end raised enough to get tires off the ground.
Vent heat was warm, so I'm guessing a lil drive will help a bit. I'll do that later today. A bit discusted with myself for not noticing the lower hose needs replaced when I had it apart!! Oh well, live & learn!!
post Nov 16, 2012 - 6:27 PM
Bigblock
Joined Feb 14, '09
From Mid West
No change.Lower hose still cold.
Lo-Fi Version Time is now: February 22nd, 2025 - 3:05 PM
