> Help identifying cams, can't figure out what the hell these things came out of
post Nov 9, 2012 - 9:20 AM
bsamps4
Joined May 16, '10
From Raleigh
So i bought a spare 3rd gen 3s head that i'm going to build, and am trying to figure out what the cams are that came in it. I'm highly skeptical that these are 3rd gen 3s cams at all, and they are NOT aftermarket. Take a look at this and let me know what you think.
Take a look at the cam lobes specifically. They have a relief cut in them on the back side pointing away from the pointy side of the lobe.
post Nov 9, 2012 - 11:51 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (bsamps4 @ Nov 9, 2012 - 10:20 AM) *
Http://i1190.photobucket.com/albums/z453/b...52470575649.jpg
Maybe they tried to reduce weight. Only the high point of the cam lobe touches the lifter, because when the valve is closed there is some clearance between the lifter and cam. So theoretically you could remove the entire lobe except for the point where its actually contacting and moving the lifter/valve and there would be no Ill effects. Though I suppose you need at least a little cam lobe left with clearance to help oil the lifter and cam,
This post has been edited by Special_Edy: Nov 9, 2012 - 11:52 AM
post Nov 9, 2012 - 5:58 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (bsamps4 @ Nov 9, 2012 - 4:20 AM) *
I'm not saying that this is what they are, but they could be non-turbo Gen III 3s cams. I'm running a non-turbo Gen III 3s head with turbo springs and cams. The cams swap out fine, so I'm sure the n/a cams would fit in a turbo head (not sure why anyone would do that though). Unfortunately I bought my head without cams in it, so I can't tell you what they look like, but maybe you can find some on ebay being sold?
This post has been edited by match220: Nov 9, 2012 - 6:00 PM
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Nov 10, 2012 - 9:00 PM
Bladey
Joined Apr 15, '11
From Auckland, NZ
As poster above me said they could be gen III cam, ( they have more duration and more lift 256 degrees)
They move the power band up more but that would be my best guess
Lo-Fi Version Time is now: November 23rd, 2024 - 6:43 PM
