> How to remove the bolt off the lower control arm?, the bolt is rusted and hard
post Nov 9, 2012 - 2:25 PM
dangqiwu
Joined Sep 9, '12
Hi guys, I got a used lower control arm but the bolt connected to the stabilizer link is rusted.
I used PB blaster but no help so far.
Any suggestion to take it off?
Thank you guys.
post Nov 9, 2012 - 2:46 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
I'd try to grab between the nut and the mount with a pair of vice grips to hold the bolt still while taking a ratchet to the nut. If that doesn't work, time to get a grinder or torch out.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 9, 2012 - 3:45 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
get some need nose vise grips and grab behind the nut where the boot is.
post Nov 9, 2012 - 4:58 PM
Syaoran
Joined Jan 4, '12
From US
Impact gun should make quick work of it... otherwise ^^^^^^
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Nov 9, 2012 - 6:13 PM
QUOTE (richee3 @ Nov 9, 2012 - 3:46 PM) *
http://www.6gc.net/forums/index.php?showtopic=41243
correct. At the point you're at I would just use a cut off wheel on my grinder.
QUOTE (Syaoran @ Nov 9, 2012 - 5:58 PM) *
Nope. An impact gun would just spin it, it's spherical.
post Nov 9, 2012 - 6:44 PM
mkernz22
Joined May 10, '10
From MA
saws all or a grinder will take it right off. That's what I had to do with one of my rear ones.
post Nov 10, 2012 - 1:35 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Batman722 @ Nov 9, 2012 - 7:13 PM) *
I've used impact guns to take off and put on endlinks enough times. Did it on my Mazda and did it on my 6GC.
post Nov 10, 2012 - 7:49 PM
get a new armcontrol
post Nov 10, 2012 - 11:44 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Cut it, as stated.
Easiest, least time consuming method, especially if you don't need it.
My Celica!
post Nov 16, 2012 - 9:09 PM
dangqiwu
Joined Sep 9, '12
QUOTE (jordisonjr @ Nov 11, 2012 - 12:44 AM) *
Cut it, as stated.
You're right. I bring it to a mechanician and he did so.
Lo-Fi Version Time is now: December 1st, 2024 - 10:00 PM
