Enthusiast ![]() Joined Dec 16, '08 From Norway Currently Offline Reputation: 0 (0%) ![]() |
Hello.
I'm looking for a drive shaft, the left side that fit the 3SGE from ST202. Anyone have one so please scream out ! ![]() -------------------- - Celica ST202 w/ JDM 3S-GE 180HP (Special LE Subaru Blue steel paint!)
- A video of my car, before & after: Click here |
![]() Enthusiast ![]() Joined Sep 22, '11 From midstate michigan Currently Offline Reputation: 0 (0%) ![]() |
Most times the outter CV is the bad one and the inner CV is good, if that is the case with yours, you should check e-bay. For right around $50.00 you can buy 2 outter joints.
That is if you dont mind doing the work yourself! |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
E56 or S54 Iceman?
Most times the outter CV is the bad one and the inner CV is good, if that is the case with yours, you should check e-bay. For right around $50.00 you can buy 2 outter joints. That is if you dont mind doing the work yourself! I know man, but this is a uncommon problem, the inner CV is damaged ![]() E56 or S54 Iceman? I need for the S54.. -------------------- - Celica ST202 w/ JDM 3S-GE 180HP (Special LE Subaru Blue steel paint!)
anyone?
Enthusiast ![]() Joined Oct 2, '12 From New York Currently Offline Reputation: 1 (100%) ![]() |
Lo-Fi Version | Time is now: February 12th, 2025 - 10:37 AM |
