Jump star=sparks, Wharf may be damaged? |
Nov 10, 2012 - 8:07 PM |
Enthusiast Joined Feb 14, '09 From Mid West Currently Offline Reputation: 7 (100%) |
Didn't notice cables were crossed
Sparks & hot cable clamps!! Starter won't engage or click. For sure 1 fuse is blown in the engine bay. Starter toast?? Possible other damage?? FML!!! I feel like such an a**!!! Any help GREATLY APPRECIATED!!! |
Nov 10, 2012 - 8:33 PM |
ECU damage is possible, but I believe the fuses are there for a reason. Remove and reattach the battery cables and clamps(the energy probably severed the connection for only 12V) and replace the fuses that are damaged. Make sure to check the fusible links(big square fuses) too, they are probably the culprits.
Nov 10, 2012 - 8:55 PM |
Thanks special!!
Can I check them with a continuity tester-- the probe thing that has the gator clamp & lightbulb Or is a multimeter needed? |
Nov 11, 2012 - 10:09 AM |
Battery is fried, check fuses, and replace the ground wire to the battery, as it is likely melted a bit.
Nov 11, 2012 - 1:52 PM |
Battery is fried, check fuses, and replace the ground wire to the battery, as it is likely melted a bit. I think all the wiring circuits should be covered by a fusible link. The fusible link will always blow before the wires get damaged. On our cars they are conveniently packaged like fuses- Of course, the Positive (B+) wire to the starter likely isnt protected by a fusible link. And I do agree with 95CelicaST, have the battery checked. You were having to jump start the car to begin with so that tells me that the battery was already dead, before you reversed the polarity. Autoparts stores will check the battery for free usually. This post has been edited by Special_Edy: Nov 11, 2012 - 1:53 PM |
Nov 11, 2012 - 7:55 PM |
Thanks guys!!! I'll be doing it Tuesday!
Nov 13, 2012 - 5:20 PM |
New battery-- A-OK!!
Nov 13, 2012 - 6:34 PM |
Genius I am.
Glad to hear everything is okay! -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Nov 13, 2012 - 7:20 PM |
Sir, you are yes!!
Thanks for the help & info.. |
Lo-Fi Version | Time is now: November 26th, 2024 - 6:59 PM |
