> Checking bushing fitment
post Nov 16, 2012 - 6:18 PM
senick
Joined Mar 29, '11
From Bloomington, IN
Will these fit the rear sway bar for a 95 ST?
http://www.amazon.com/Energy-Suspension-8-...n+16mm+bushings
I read that they're 16mm. And as far as putting them on, once the end links are off is it just of process of sliding the old ones off and sliding the new on? Or is there a slit to where they just clamp over the bar?
post Nov 17, 2012 - 7:13 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The bushings are split. I would recommend thoroughly cleaning the bar, as the grease provided with polyurethane bushings is very sticky and will pick up any contaminants it comes near. If you find it difficult to get the bracket back into place, a little brake grease can make the process easier without damaging the polyurethane. Don't use a petroleum-based lubricant.
post Nov 17, 2012 - 8:01 AM
senick
Joined Mar 29, '11
Great, thank you for that information, that will help a lot. Now, will any 16mm rear bushings work for the stock sway bar?
post Nov 17, 2012 - 5:46 PM
Syaoran
Joined Jan 4, '12
From US
Any universal one should work. Reusing the stock brackets is a different story. You're going to be better off using the brackets that usually are provided.
I personally purchased Prothane bushings with brackets for my rear one (GT 17mm)
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
Lo-Fi Version Time is now: December 1st, 2024 - 7:15 PM
