> Shifter Base Bushings..., ... a MUST HAVE!
post Nov 16, 2012 - 8:28 PM
Syaoran
Joined Jan 4, '12
From US
So I installed a set of aluminum shifter bushings for the MR2. The fit perfectly onto my shifter base.
If you have the time, make sure to take out most of the plastics in the middle console. If you don't, get ready to get cuts like I did.
The shifter is rock solid now, I'm even afraid I might break the shift rod haha, but it's so nice. Feels more connected. I'm still missing the second shifter cable bushing, and I can already feel a difference in shift feel. A must have for a couple of bucks and half an hour of your time.
Here's a pic of the old ones. Couldn't snap a pic of the new ones installed cause they're barely visible once installed.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Nov 19, 2012 - 10:33 PM
Are the new ones brass, soft metal type?
post Nov 20, 2012 - 2:17 AM
UVZ164
Joined Sep 30, '11
From Sydney
Are they the speed source ones? If so you can select the option for the 6gc.
http://speed-source.net/?wpsc-product=toyo...n-base-bushings
post Nov 20, 2012 - 7:30 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
monkeywrench racing has them as well.
Id buy them there, Speed Source is very lazy with shipping and has no communication line
エキサイティングカーレーシングチーム!
post Nov 20, 2012 - 9:38 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (SwissFerdi @ Nov 19, 2012 - 11:33 PM) *
Aluminum.
QUOTE (UVZ164 @ Nov 20, 2012 - 3:17 AM) *
Yes the speedsource ones. Most FWD Toyotas and the MR2 and MR-S use the same bushings.
QUOTE (Tigawoods @ Nov 20, 2012 - 8:30 AM) *
twosrus shipped extremely fast, I'm not complaining.
post Nov 20, 2012 - 11:06 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Both twos r us and monkey wrench are really great with communication and shipping
エキサイティングカーレーシングチーム!
post Nov 20, 2012 - 11:37 AM
Excellent. I'm waiting to install these, glad to hear they're up to standard.
This post has been edited by SwissFerdi: Nov 20, 2012 - 11:37 AM
post Nov 20, 2012 - 1:17 PM
JasonX
Joined Oct 18, '07
From Orange County, CA
Hey guys, do you think these would work with TWM short shifter as well?
post Nov 20, 2012 - 6:05 PM
Syaoran
Joined Jan 4, '12
From US
They're supposed to. If the shifter uses the same base mounting points as stock (which it should) then yes, they'll fit.
post Nov 20, 2012 - 7:09 PM
JasonX
Joined Oct 18, '07
Thanks. Do you have plans on changing the shifter cable bushings as well?
QUOTE (Syaoran @ Nov 20, 2012 - 3:05 PM) *
post Nov 20, 2012 - 8:32 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (JasonX @ Nov 20, 2012 - 8:09 PM) *
Yes. I already put one of the two in.
I bought a set of brass bushings from ebay but the kit came with 2 bushings which are different in size. The smaller one is the correct bushing for both cables.
I believe the MR2 N/A kit from speedsource will fit, as I think they're the same size as the Celica.
I talked to the seller on eBay and he'll simply swap the larger one for a smaller one for me.
post Nov 22, 2012 - 1:47 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
So these go to the base of the shifter assembly? Does the mount really move that much? I may have to try this.
post Nov 23, 2012 - 3:15 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (RabidTRD @ Nov 22, 2012 - 2:47 PM) *
Yes.
Go ahead and remove the shift bezel, grab the shifter base and try to move it. Mine had a TON of play.
Lo-Fi Version Time is now: November 29th, 2024 - 1:02 PM
