> Toyota OEM "Engine Overhaul Gasket Kit"..., ...what the F*(&() does it really include?
post Nov 16, 2012 - 11:09 PM
Syaoran
Joined Jan 4, '12
From US
Date: Monday, November 19 2012 02:10 PM
Subject: RE: BIG order...
UPDATE:
1) The contents of an engine overhaul gasket set vary from one engine to another. Basically, 04111-74512 does include these parts:
Head gasket
Valve cover gasket
Valve cover grommets
Timing cover gasket
Valve stem seals
Camshaft seal
Intake manifold gasket
Exhaust manifold gasket
Throttle body gasket
Oil cooler o-rings
Front crankshaft seal
Oil pump gasket
Rear crankshaft seal
Rear main seal retainer gasket
Water outlet gasket
Water bypass pipe gaskets and o-rings
Fuel injector o-rings and insulators
Thermostat gasket (also supplied with water pump)
It does not include these parts:
1. Oil pan gasket (use FIPG oil sealant 00295-00103; there is no oil pan gasket)
2. Oil pump shaft seal 15165-88382 (the oil pump is sold as an assembled unit w/ seal installed)
3. Oil pump o-ring 15188-03011 (the oil pump is sold as an assembled unit w/ o-ring installed)
4. Water pump gasket (the water pump is sold as an assembled unit w/ gasket installed)
2) I do not know if this was a question or not. Water pump is 16100-79185-83. Your VIN calls for oil pump 15100-74060. The most recent Camry 5S-FE oil pump is 15100-74030. Toyota does not give us engineering data or flow rates, so if you want to deviate from stock, you will need to do your own research on the forums to determine which parts to use.
3) The gasket set most likely includes the same type of head gasket the car came with. We cannot make substitutions. If you want a different one you will need to order it separately. The part number for a later model head gasket is 11115–74120.
4) I do not know if this was a question or not. Idler no.1 is 13505-74011; tension spring is 90507-17003; idler no.2 is 13503-63011.
Does anybody know what the so called "Engine Overhaul Gasket Kit" from Toyota include? I contacted a parts reseller that only sells OE toyota stuff and he simply sent me a diagram which looks like playdoh figures with some lines and stuff. I asked if he had a list of the parts that it included and he said "no, sorry, this is all I have''...
This post has been edited by Syaoran: Nov 20, 2012 - 6:40 PM
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Nov 16, 2012 - 11:29 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
it comes with everything. period. including head gasket, and yes its factory 3 layer steel
anything missing from it will come with other parts.
example, if you buy the 2 piece water pump (pump and housing) it will come with new orings n ****
Mike W
269awhp / 273ft-lbs
post Nov 16, 2012 - 11:53 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (delusionz @ Nov 17, 2012 - 12:29 AM) *
Even for MY94 Celicas? At least for the MR2 guys, their 3SGTE kit for 92 3SGTE comes with a graphite gasket from the factory, because that year came with graphite headgasket.
I contacted Lithia Toyota to see what they tell me.
post Nov 17, 2012 - 12:49 AM
delusionz
Joined Feb 11, '08
well, if you're talking about an st205 gasket kit then yeah, assuming thats what you're going to order
Mike W
269awhp / 273ft-lbs
post Nov 17, 2012 - 12:56 AM
delusionz
Joined Feb 11, '08
sorry, are you meaning st204 gasket kit? i got no idea on their head gasket sorry, but likewise on it including everything
Mike W
269awhp / 273ft-lbs
post Nov 17, 2012 - 1:00 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (delusionz @ Nov 17, 2012 - 1:56 AM) *
Yes it's for a 5S-FE.
post Nov 18, 2012 - 12:49 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
it will come with the metal head gasket, all the gasket kits come with metal gaskets now. the 7A originally came with a graphite gasket, now they come with a metal gasket. if you feel better, get one thats for a 99 celica. it will have everything. all the valve seals, cam seals, front and rear mains. the only gaskets it doe snot come with are the oil pump gaskets for on the pump. the one under the pulley and the wing shape inside the pump
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 18, 2012 - 4:46 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Smaay @ Nov 18, 2012 - 1:49 AM) *
Thanks,
I'm guessing the oil pump assembly should bring everything but the cork/rubber gasket for the pump right?
I have a couple of questions regarding the 98+ oil pump but I'll search for those first.
post Nov 19, 2012 - 12:08 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
the oil pump gasket will be metal. if you get a new pump, it will have the new seals in it already.
post Nov 20, 2012 - 6:53 PM
Syaoran
Joined Jan 4, '12
From US
Updated the first post. Got a reply from Lithia Toyota of Springfield with some part numbers as well. For those whom this may be of benefit, glad I could help.
Lo-Fi Version Time is now: February 22nd, 2025 - 9:59 AM
