![]() Enthusiast ![]() ![]() Joined Mar 4, '10 From Bronx NY Currently Offline Reputation: 3 (100%) ![]() |
On my Caldina ST-215 engine, I have on there the original water temperature sensor which gives me a good signal out (meaning the gauge on the cluster says its just below middle when warmed up, NORMAL) My problem with my car is that it burns incredible amounts of gas. one of the symptoms of that is a bad water temp sensor many say.
So I go ahead and three times I changed the sensor to one i purchased online, auto-zone, and pep-boys. Every time I place the new one in my gauge starts off cold then spikes all the up to HOT and seems to past it lol. I checked the sensor for the ST-215 is: DENSO 89422‑16010 which is the same used in North American built cars in: 06/2003-07/2005 TOYOTA ECHO NCP13 84-04: ELECTRONIC FUEL INJECTION SYSTEM 04/2003-11/2006 SCION XB NCP31 84-04: ELECTRONIC FUEL INJECTION SYSTEM 01/2001-10/2005 TOYOTA YARIS SCP1*, NLP10 84-04: ELECTRONIC FUEL INJECTION SYSTEM 04/2003-11/2006 SCION XA NCP61 84-04: ELECTRONIC FUEL INJECTION SYSTEM 09/1994-06/1999 TOYOTA TERCEL EL53 84-04: ELECTRONIC FUEL INJECTION SYSTEM 08/1999-10/2005 TOYOTA ECHO NCP12 84-04: ELECTRONIC FUEL INJECTION SYSTEM 08/1995-06/1999 TOYOTA PASEO EL54 84-04: ELECTRONIC FUEL INJECTION SYSTEM 08/1997-12/2001 TOYOTA COROLLA ZZE110 84-04: ELECTRONIC FUEL INJECTION SYSTEM 07/2001-01/2006 TOYOTA CAMRY ACV30,MCV3* 84-04: ELECTRONIC FUEL INJECTION SYSTEM 07/2001-12/2005 TOYOTA CAMRY ACV30,MCV3* 84-04: ELECTRONIC FUEL INJECTION SYSTEM 06/1998-11/2002 TOYOTA SOLARA ACV20,MCV20,SXV20 84-04: ELECTRONIC FUEL INJECTION SYSTEM Now every time I place the original sensor back the gauge stays in the normal range. What does this mean? I'm replacing it with the correct part but all the other ones tell me I'm running hot at idle. PS: No the engine doesn't seem hot. It seems as if it is as hot as any other engine when touching it, and also when I put the replacement sensor in and rev the engine, it goes past hot but if you let it idle the needle goes to about 80 -90% up the gauge. Thanks Guys always for your help -------------------- Always fast and going for the look......
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) ![]() |
The sensor which sends a signal to your instrument panel is not the same one that the ECU uses to manage the air-fuel ratio.
![]() Enthusiast ![]() ![]() Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) ![]() |
Hi,
The sensor which sends a signal to your instrument panel is not the same one that the ECU uses to manage the air-fuel ratio. it is the same sensor, on the gen.3 3S-GTE you found two sensors one for the ECU (2pins) and a other one for the combi meter (1 pin), the gen.4 engine uses a cobinations of that ones means two sensors are in one housing and uses 3 pins, the resistance is the same on all ones greetz -------------------- |
Hi, The sensor which sends a signal to your instrument panel is not the same one that the ECU uses to manage the air-fuel ratio. it is the same sensor, on the gen.3 3S-GTE you found two sensors one for the ECU (2pins) and a other one for the combi meter (1 pin), the gen.4 engine uses a cobinations of that ones means two sensors are in one housing and uses 3 pins, the resistance is the same on all ones greetz ok sounds right but whats causing my problem ? I mean why when replacing it with the correct sensor (only differences is that its new) do the engine reads its hot but when placing the original it shows me its normal (just below middle) on the comb. meter ? This post has been edited by timdog1720: Nov 18, 2012 - 10:16 AM -------------------- Always fast and going for the look......
On my Caldina ST-215 engine, I have on there the original water temperature sensor which gives me a good signal out (meaning the gauge on the cluster says its just below middle when warmed up, NORMAL) My problem with my car is that it burns incredible amounts of gas. one of the symptoms of that is a bad water temp sensor many say. So I go ahead and three times I changed the sensor to one i purchased online, auto-zone, and pep-boys. Every time I place the new one in my gauge starts off cold then spikes all the up to HOT and seems to past it lol. I checked the sensor for the ST-215 is: DENSO 89422‑16010 which is the same used in North American built cars in: 06/2003-07/2005 TOYOTA ECHO NCP13 84-04: ELECTRONIC FUEL INJECTION SYSTEM 04/2003-11/2006 SCION XB NCP31 84-04: ELECTRONIC FUEL INJECTION SYSTEM 01/2001-10/2005 TOYOTA YARIS SCP1*, NLP10 84-04: ELECTRONIC FUEL INJECTION SYSTEM 04/2003-11/2006 SCION XA NCP61 84-04: ELECTRONIC FUEL INJECTION SYSTEM 09/1994-06/1999 TOYOTA TERCEL EL53 84-04: ELECTRONIC FUEL INJECTION SYSTEM 08/1999-10/2005 TOYOTA ECHO NCP12 84-04: ELECTRONIC FUEL INJECTION SYSTEM 08/1995-06/1999 TOYOTA PASEO EL54 84-04: ELECTRONIC FUEL INJECTION SYSTEM 08/1997-12/2001 TOYOTA COROLLA ZZE110 84-04: ELECTRONIC FUEL INJECTION SYSTEM 07/2001-01/2006 TOYOTA CAMRY ACV30,MCV3* 84-04: ELECTRONIC FUEL INJECTION SYSTEM 07/2001-12/2005 TOYOTA CAMRY ACV30,MCV3* 84-04: ELECTRONIC FUEL INJECTION SYSTEM 06/1998-11/2002 TOYOTA SOLARA ACV20,MCV20,SXV20 84-04: ELECTRONIC FUEL INJECTION SYSTEM Now every time I place the original sensor back the gauge stays in the normal range. What does this mean? I'm replacing it with the correct part but all the other ones tell me I'm running hot at idle. PS: No the engine doesn't seem hot. It seems as if it is as hot as any other engine when touching it, and also when I put the replacement sensor in and rev the engine, it goes past hot but if you let it idle the needle goes to about 80 -90% up the gauge. Thanks Guys always for your help bump -------------------- Always fast and going for the look......
Hi, The sensor which sends a signal to your instrument panel is not the same one that the ECU uses to manage the air-fuel ratio. it is the same sensor, on the gen.3 3S-GTE you found two sensors one for the ECU (2pins) and a other one for the combi meter (1 pin), the gen.4 engine uses a cobinations of that ones means two sensors are in one housing and uses 3 pins, the resistance is the same on all ones greetz Ah, my bad -- missed that it was a 215. |
bump
Enthusiast ![]() Joined Jan 28, '07 From Québec, Canada Currently Offline Reputation: 1 (100%) ![]() |
In my ST215 swap, I didn't use the 3rd wire in the ST215 coolant temp sensor to drive the coolant temp gauge. Instead, I've use the original ST184 (in my case) coolant temp sender to the gauge.
A broken coolant sensor should set a check engine code. Enter in diagnosis mode by sending the pin TC of the ECU to ground and see if the check engine light is giving any code (assuming you have connected the pin W of the ECU to the check engine light in the dash). A wideband AFR sensor should be another good investment to see if your car is running excessively rich in normal cruise condition. |
Lo-Fi Version | Time is now: February 20th, 2025 - 4:21 PM |
