Enthusiast ![]() Joined Sep 9, '12 Currently Offline Reputation: 0 (0%) ![]() |
Are these tools necessary for replacing wheel bearing of 6G Toyota Celica?
hub & dust cap pliers ![]() bearing packer ![]() bearing race punch ![]() bearing race & seal set ![]() This post has been edited by dangqiwu: Nov 18, 2012 - 2:07 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
you'll need the pliers if you intend to keep the dust cap. but the dust cap bends easily and when that happens you're screwed. so you're better ordering a new dust cap than the pliers.
if the bearing packer is to pack grease into the bearing, then it's not needed if you're replacing the bearing. bearings are pre-greased already. bearing race punch is not needed. bearing race and seal set is needed and they're used for a hydraulic press. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Enthusiast ![]() ![]() ![]() ![]() Joined Sep 27, '10 From pittsburgh Currently Offline Reputation: 4 (100%) ![]() |
Races are kinda needed, I have axle nut sockets that I use to press the bearings out. Then use the old bearing with thick steel on top still to press them in.
Punch, packer, not needed. Just use needle nose pliars to remove the snap ring. Do you have a press, and have you ever done it before? They can be tricky. You will need a bearing seperator. The inside inner race of the old bearing will be stuck on the hub when you press it out. This post has been edited by czwalga: Nov 18, 2012 - 4:46 PM -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD -10 F150 Always buying stock wheels... PM me if interested in selling. |
Thank @azian_advanced and @czwalga
I found no need to use hub & dust cap pliers because there is no dust cap at all. As you said I don't need to buy bearing packer and bearing race punch. I'll get a bearing race & seal set or a single one of them. I don't have a press. May I use a hammer instead? |
Thank @azian_advanced and @czwalga I found no need to use hub & dust cap pliers because there is no dust cap at all. As you said I don't need to buy bearing packer and bearing race punch. I'll get a bearing race & seal set or a single one of them. I don't have a press. May I use a hammer instead? No chance in hell you'll be able to do with a hammer. I have a 20 ton press and sometimes it's not even enough to remove the bearing without heat. They usually go in fairly easy with a press though. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
I seriously doubt it. I use my dad's 25-ton press and I can feel a decent amount of resistance in the handle as I pump it to press the bearing in/out. So 1-ton definitely won't cut it. I'd say about 10-15 ton minimum.
I seriously doubt it. I use my dad's 25-ton press and I can feel a decent amount of resistance in the handle as I pump it to press the bearing in/out. So 1-ton definitely won't cut it. I'd say about 10-15 ton minimum. Found this 12 ton press at Harbor Freight. Only $129.99 plus $6.99 shipping. ![]() This post has been edited by dangqiwu: Nov 20, 2012 - 10:12 PM |
The 12 ton will probably work. I have the 20ton from harbor freight, but i've used a 12 ton before and it did work for bearings but it was kinda right on the edge.
The harbor freight 6 ton is junk, I have one of those also, dont waste your money. Just to let you know you're going to need steel plates or something to level everything when you set it in there. The knuckle doesnt just sit in there perfectly and you can press it out. I have a bunch of scrap steel, from 1", 1/2", 1/4", 1/8" steel to stack and level the knuckle. If you dont do this often, you can just take the knuckles to a small shop. They usually charge $25 a knuckle. Unless you're changing bearings a lot it would probably save you money and a lot of stress. This post has been edited by czwalga: Nov 20, 2012 - 7:11 AM -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
The 12 ton will probably work. I have the 20ton from harbor freight, but i've used a 12 ton before and it did work for bearings but it was kinda right on the edge. The harbor freight 6 ton is junk, I have one of those also, dont waste your money. Just to let you know you're going to need steel plates or something to level everything when you set it in there. The knuckle doesnt just sit in there perfectly and you can press it out. I have a bunch of scrap steel, from 1", 1/2", 1/4", 1/8" steel to stack and level the knuckle. If you dont do this often, you can just take the knuckles to a small shop. They usually charge $25 a knuckle. Unless you're changing bearings a lot it would probably save you money and a lot of stress. Good to know these. Thanks! Btw, I saw some video on how to replace wheel bearing but they only use a race & seal set with a hammer. I guess Toyota is different. This post has been edited by dangqiwu: Nov 20, 2012 - 4:42 PM |
The 12 ton will probably work. I have the 20ton from harbor freight, but i've used a 12 ton before and it did work for bearings but it was kinda right on the edge. The harbor freight 6 ton is junk, I have one of those also, dont waste your money. Just to let you know you're going to need steel plates or something to level everything when you set it in there. The knuckle doesnt just sit in there perfectly and you can press it out. I have a bunch of scrap steel, from 1", 1/2", 1/4", 1/8" steel to stack and level the knuckle. If you dont do this often, you can just take the knuckles to a small shop. They usually charge $25 a knuckle. Unless you're changing bearings a lot it would probably save you money and a lot of stress. Good to know these. Thanks! Btw, I saw some video on how to replace wheel bearing but they only use a race & seal set with a hammer. I guess Toyota is different. Hmm well i've searched and probably saw a similar video. It maay work, but you could run into a bearing that just wont budge with the sledge. This post has been edited by czwalga: Nov 20, 2012 - 8:37 PM -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
if its the front bearing, take it to a shop.
the rears, just buy the whole setup and swap. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
It should be only $20 to $30, per side, for a shop to replace the bearings. That's about how much it was when I had to do one.
It should be only $20 to $30, per side, for a shop to replace the bearings. That's about how much it was when I had to do one. Show a repair record at a local shop. 12/10/2007 Labor REPLACE BOTH C/V SHAFTS, 60*2(hours)=120 C/V SHAFTS, $83.73*2=167.46 Labor REPLACE BOTH FRONT WHEEL BEARINGS, 60*3.5(hours)=210 WHEEL BEARINGS, $72*2=144 TRANSMISSION FLUID, 2.99*2=5.98 --------------------------------------------------------------------------------------- Sub-Total 647.44 Total(8.75%TAX) 675.21 |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
at the most its just basic tools, and usually its good to have a front end service tool kit. then you can either press it if you have it or bring it in.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) ![]() |
A hammer will work but you need to know what your doing in order to get the bearing seated properly without wobbling.
Enthusiast Joined Dec 28, '11 From GA Currently Offline Reputation: 0 (0%) ![]() |
QUOTE Labor REPLACE BOTH FRONT WHEEL BEARINGS, 60*3.5(hours)=210 WHEEL BEARINGS, $72*2=144 That labor charge includes removing the hubs, pressing out/in the bearing and reassembling the hubs. If you do the majority of the labor and just walk into the shop holding the hubs and new bearings, the labor charge just to press bearing out/in will be about $20-$30 for each side |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) ![]() |
Please please PLEASE, don't use a hammer.
As stated before, take it to a shop just to press the bearing in and do the rest of the work yourself. Had a guy from toyota doing my bearings, and they kept wearing out and a couldn't figur eout why, untill I realized he was simply hammering them in instead of using a press. They will wear out quick, and you'll be throwing moeny at your car all the time. Do it right so you don't have to do it again. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Lo-Fi Version | Time is now: April 22nd, 2025 - 8:33 PM |
