> egr MT/AT??, CEL on
post Nov 20, 2012 - 2:53 PM
yaj204
Joined Nov 29, '07
From california, marysville
i replaced my motor a year ago and my check engine light was on ever since, i replaced alot of parts and now the car is running good but the light is still on and it reads the egr. my question is if the motor was from an automatic trans, will that affect it? and can someone who has a 99 celica gt with a manual trans give me a code number?? thanks
post Nov 20, 2012 - 8:49 PM
SallyGloryShine
Joined May 12, '04
From Madison TN
Trans shouldn't affect an EGR code. Which code is it?
post Nov 20, 2012 - 9:12 PM
mkernz22
Joined May 10, '10
From MA
The transmission has nothing to do with the EGR. What year engine did you get when you replaced the original one?
post Nov 20, 2012 - 11:45 PM
yaj204
Joined Nov 29, '07
QUOTE (mkernz22 @ Nov 20, 2012 - 9:12 PM) *
i dont remember what year. but i think it was 97-99
post Nov 20, 2012 - 11:51 PM
yaj204
Joined Nov 29, '07
QUOTE (SallyGloryShine @ Nov 20, 2012 - 8:49 PM) *
i think it gave me code P0401... if not i will repost it. but at first it was bobbing and stalling so i switched out the vsv sensor and that solved the problem but still giving me the same code
post Nov 21, 2012 - 3:17 AM
pandakid
Joined Feb 12, '06
From Fresno CA
might be clogged,mine was really bad in my ae86.i think you can check buy renting a vacuum gun at autozone,shoot some air on the top of the egr and if the idel doesnt change its clogged.have you tried resetting your code or unplugging your battery terminals to reset the code?
post Nov 21, 2012 - 4:58 PM
yaj204
Joined Nov 29, '07
QUOTE (pandakid @ Nov 21, 2012 - 3:17 AM) *
i cleaned the egr, still havent reset the code. and i did try shooting some air in it with a pump but nothing happened... i am guessing i need a new egr. can the egr b dead or bad besides being clogged?
post Nov 21, 2012 - 5:38 PM
pandakid
Joined Feb 12, '06
From Fresno CA
yea maybe the egr diaphragm,can be bad.double check if the nipple is clogged.you have to unscrew it.but that was on my ae86.i havnt pulled my egr out of my celica yet
This post has been edited by pandakid: Nov 21, 2012 - 5:39 PM
Lo-Fi Version Time is now: January 10th, 2025 - 11:41 AM
