> ABS light
post Nov 21, 2012 - 7:05 PM
revelsumgt
Joined May 9, '11
Can someone please help me with this ABS problem
I managed to get codes for the abs light that remains on
Code 11 Open in solenoid relay circuit. Check actuator wiring
harness, solenoid relay, solenoid relay wiring harness and solenoid
relay connector. See SOLENOID RELAY under COMPONENT TESTING
Code 31 Front right sensor
Code 32 Front left sensor
Code 33 Rear right sensor
Code 34 Rear left sensor
Is it really possible for all my sensors to be out??
Stuck on what to do.. any advice would be helpful. P.s. celica is an ST
codes 31-34 are the sensors @ each wheel
post Nov 22, 2012 - 2:45 AM
phrax
Joined Jul 28, '10
From BC, Canada
Pop the wheels off and check that the sensors are actually there. When I bought mine some PO clipped the front sensors and I was getting both 31 and 32. If they're there, check all the connections to see if they're nice and clean, no broken wires, etc. Just the regular troubleshooting.
post Nov 22, 2012 - 3:22 PM
revelsumgt
Joined May 9, '11
So i changed the relay switch from my other celica.
I pumped the brake pedal 8 times to reset. Now I'm just getting a code 32.
It's very strange because it showed a code 32 in my other celica as the abs light is on in that
I'm just wondering, how good is this diagonstics? It sounds a bit stupid and misleading...
post Nov 23, 2012 - 2:05 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Pull the bulb and forget about it, unless you're winter driving it.
My abs sensors broke years ago when I had the wheel bearings changed, didn't want to shell out the cash to replace the sensors as I don't winter drive mine.
My Celica!
post Nov 25, 2012 - 5:34 PM
revelsumgt
Joined May 9, '11
You can't do that in england dude. The abs light has to flash with a sequence of numbers. Anyway, the good news is i've fixed it. I took another sensor out of my old celica and it worked. The problem is it's designed for a right hand side, not a left, so I had to bodge it into place! lol.
That's one problem down, a list to go.. she's black with 17" alloys, very tidy so worth it!
Lo-Fi Version Time is now: April 22nd, 2025 - 2:36 PM
