> Crossmember/Brace, 95 GT ATM -> 95 GT MTM
post Nov 22, 2012 - 12:00 PM
travisxcore
Joined Mar 24, '11
From 704
So the crossmember brace that goes from the front towards the back and has 2 of the motor mounts on it doesn't want to fit in place now that I put a manual it. It can be bolted in but its pushed up against the transmission sleeve (the thing that bolts onto the transmission on the bottom to keep grime from going into it)
The motor isn't sitting exactly how its supposed to but I was hoping to remedy this by putting in the crossmember. Only issue is now it leans up on the transmission sleeve. So is there a different crossmember between automatic and manual GTs or is the motor just in so much of a bind its making it seem like it wouldn't work properly?
post Nov 22, 2012 - 12:11 PM
fussellbug
Joined Dec 28, '11
From GA
The front/rear member is the same for all AT200/ST204. Did you get a manual transmission right side mount? The mounts for auto and manual are not the same and could cause misalignment if you use the auto mount on the manual transmission.
post Nov 22, 2012 - 5:07 PM
trdproven
Joined Aug 2, '05
From Guam
the crossmembers are the same or at least i know both work either way. in fact when i converted, the only thing i had that was M/T mount was the driver side (tranny side), i had all A/T mounts for front, rear, and passenger for quite a while. It was only when the front mount went bad, that I changed both front and rear to M/T. In fact, my passenger is still A/T mount.
I could possibly agree with you that there could be a misalignment in some sense, at first thats what I thought would happen. but at the end, i believe there is some tolerance to it, and basically it all went in fine with just the passenger tranny M/T mount.
I hope that answers your question.
This post has been edited by trdproven: Nov 22, 2012 - 5:08 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Nov 23, 2012 - 3:55 PM
travisxcore
Joined Mar 24, '11
From 704
I was thinking the subframe would work either way but it was just being such a pain trying to get it all to fit with the motor so unaligned. Its already snapped the EGR vacuum valve and shredded the accessory cause it won't sit correctly. I even lowered the A-arms just so I'd have more room to play with the crossmember.
I got all new mounts but I didn't order the plate that the driver mount sits on ontop of the transmission, instead I just took a grinder and cut off the extra piece and sized up the holes so the bolts would fit in correctly. I'm gonna try to bolt it all up and see if it doesn't align itself.
This post has been edited by travisxcore: Nov 23, 2012 - 3:58 PM
Lo-Fi Version Time is now: December 3rd, 2024 - 2:03 AM
