![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) ![]() |
looking to sell 4 hubcentric 20mm spacers i bought for the celica. Have yet to put them on for the past year and decided to go with a diffrent rim with diffrent offset and have found that i dont need the spacers. The spacers are the ones which bolt up to the hub and have their own studs pressed into them.
The spacers are made for rims that have a void/space for the existing studs on the hub to fit into once the spacer is bolted to the hub and the rim bolted to the spacer. 100 shipped anywhere in the US This post has been edited by urbandork: Dec 17, 2012 - 9:38 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) ![]() |
The spacers are made for rims that have a void/space for the existing studs on the hub to fit into once the spacer is bolted to the hub and the rim bolted to the spacer. 100 shipped anywhere in the US What do you mean by this? Pics? Do the studs from the hub sit flush once the spacer is bolted on, or do they protrude? -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) ![]() |
The spacers are made for rims that have a void/space for the existing studs on the hub to fit into once the spacer is bolted to the hub and the rim bolted to the spacer. 100 shipped anywhere in the US Do the studs from the hub sit flush once the spacer is bolted on, or do they protrude? It would depend on how long your original studs you have in are. Like I have extended studs, so they would protrude a bit His are similar design (not brand I presume) to the ones I am selling. -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
The spacers are made for rims that have a void/space for the existing studs on the hub to fit into once the spacer is bolted to the hub and the rim bolted to the spacer. 100 shipped anywhere in the US What do you mean by this? Pics? Do the studs from the hub sit flush once the spacer is bolted on, or do they protrude? std studs are usually to long for most spacers and usually need to be cut if the rim does not have a void for them... however with this spacer when it is bolted to the hub the nuts which hold the spacer to the hub do not sit flush with the spacer. |
Oh okay. I don't like the idea of cutting threaded stuff, but thanks! GLWS!
Bump
![]() Enthusiast ![]() ![]() ![]() Joined Oct 25, '11 From Tbilisi Currently Offline Reputation: 3 (100%) ![]() |
can you post the pics?
Thanks -------------------- |
as requested. this a pic of a pair bolted together to show what i was talking about before. the other pair is exactly the same.
As you can see they are new and never used since i decided to go with a different rim all together. As you can see not to much of the bolt will have to be shaved/ground off if used with a rim that doesnt have a space for an extruding stud and nut. Keep in mind if the rim doesnt have this void the stud on the hub will have to be cut down anyway... best way to do this is to thread a nut on and then cut so when you unthread the nut it will clean up the threads. ![]() ![]() ![]() This post has been edited by urbandork: Dec 10, 2012 - 1:29 PM |
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) ![]() |
4 of them shipped. 20mm, celica hubcentric 5x100... hmmm
tempting. interested in any trades? -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
4 of them shipped. 20mm, celica hubcentric 5x100... hmmm tempting. interested in any trades? nope. just good old paypal. I figured they have been sitting around not doing anything so i might as well sell them. This post has been edited by urbandork: Dec 13, 2012 - 6:17 PM |
Enthusiast Joined Nov 12, '12 From birmingham Currently Offline Reputation: 0 (0%) ![]() |
How much shipped to uk?
sold to mkernz22 pending paypal.
Lo-Fi Version | Time is now: February 23rd, 2025 - 12:56 AM |
