Enthusiast ![]() ![]() Joined Mar 1, '12 From iowa Currently Offline Reputation: 0 (0%) ![]() |
I have 3rd gen 3sgte engine.
New parts that i want to install are Headgasket Waterpump Timing belt Idle and tensioner pulleys Maybe even piston rings Will the st185 parts work for this? This post has been edited by blackliftback: Nov 27, 2012 - 3:40 PM |
![]() Enthusiast ![]() ![]() Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) ![]() |
No they wont, they are different. Maybe the timingbelt is the same and maybe the pistonrings but the rest certainly not
-------------------- JDM ST205
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
i wouldnt even chance the rings. get the right pars for the generation engine
Enthusiast ![]() Joined Dec 3, '08 From Summerville, SC Currently Offline Reputation: 0 (0%) ![]() |
You can use a Gen2 water pump in the gen3 housing, timing belts are the same, rings are the same. pulleys are different, and head gasket is different.
sheesh guys, you need to read the sticky's more often! :-) -------------------- www.tweakdperformance.com
sales@tweakdperformance.com |
Why do you want to change the piston rings and headgasket?
You can use a Gen2 water pump in the gen3 housing, timing belts are the same, rings are the same. pulleys are different, and head gasket is different. sheesh guys, you need to read the sticky's more often! :-) ugh got schooled ![]() This post has been edited by Smaay: Nov 28, 2012 - 10:46 AM -------------------- 2001 Celica GT-S Turbo
Thanks for the info.
Im going to replace these parts before i drop in the swap. Now can you guys help me on where i can purchase these parts brand new? And not via ebay. Could i go to the local toyota dealership and order thru them from toyota japan? With parts number of course. |
Why do you want to change the piston rings and headgasket? Easier to do it while its out of my car. And since i will do the headgasket... might as well change out the piston rings while the head is off. I am going to change out these parts so i wont have to worry about a headgasket leak or timing belt going bad. I know i wont be able to resist having a heavy foot after the swap ;P I plan for autoX btw. |
You do realize that changing the pistonrings involves the complete piston needs to be taken out?
I really dont see the need for this unless you want to do a complete overhaul of the entire block like new pistons, reboring the cylinders, new bearings etc. If you cant order the parts you need in the US, I can order them for you and ship things over if you'd like. -------------------- JDM ST205
You do realize that changing the pistonrings involves the complete piston needs to be taken out? I really dont see the need for this unless you want to do a complete overhaul of the entire block like new pistons, reboring the cylinders, new bearings etc. If you cant order the parts you need in the US, I can order them for you and ship things over if you'd like. I know the pistons come out and the block gets honed. New main bearings... ect. If the pistons have no damage then i will just clean them up. I remember there was a part number list but i cant seem to find it when i need it lol. I will talk to toyota dealer first. If they cant get it then i will pm you sir. Thank you for the help This post has been edited by blackliftback: Nov 28, 2012 - 2:20 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) ![]() |
You can use a Gen2 water pump in the gen3 housing, timing belts are the same, rings are the same. pulleys are different, and head gasket is different. sheesh guys, you need to read the sticky's more often! :-) Are you sure the timing belts are the same? I don't believe so. Maybe I'm thinking the valve cover gaskets are different. Could be both. |
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) ![]() |
ebay.co.uk has the 3rd gen HG kit...
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) ![]() |
This post has been edited by enderswift: Nov 28, 2012 - 7:10 PM -------------------- ![]() |
Enthusiast ![]() Joined Nov 7, '09 From Victoria BC Currently Offline Reputation: 0 (0%) ![]() |
Timing belt is different than the ST185. I think it was a tooth or two off.
1st and 2nd gen have 178 teeth, 3rd gen has 177!
Lo-Fi Version | Time is now: February 13th, 2025 - 6:33 PM |
