![]() Enthusiast ![]() ![]() Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) ![]() |
Hi there I am having issues with my #2 spark plug. Oil keeps draining on it. I changed the VC gasket and the 4 top round rubbers but halfway down the little tube oil is coming in from a slit . Is that another gasket or grommet AI didn't replace yet. I keep tightening VC and cleaning oil out but it comes back and gives me the p0240 code I believe.
Thanks http://squawkr.org/index.html Had to use my old website as storage. |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
sounds like the tube is damaged, you need to replace it
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) ![]() |
Assuming you're running a GT, the 5SFE has removable spark plug tubes -- they're screwed in, with the threads sealed by a high-temp thread locker equivalent to blue Loctite.
However, that sealant prevents oil from working up onto the bottom of the spark plug. Oil from the top is typically due to a failue of the tube gaskets at the top, but since you've changed those and you've found a slit in the side of the tube, I'd agree with Smaay. I'd love to know how this happened, if you'd care to update us when you replace it. If you don't have a chain wrench, the other way to unscrew the spark plug tubes is to use two of the valve cover nuts. Spin one on upside down, then the second rightside up, so that the shoulders of the nuts are pressed against each other. Use a large wrench (e.g. a monkey wrench) to grip the bottom nut and unscrew the tube -- the upper nut will act as a locknut and hold the bottom nut in place. Don't forget to reseal the threads when you install the replacement tube; high-temp blue Loctite is recommended by Toyota, but FIPG will also work. Don't use a common RTV, however. |
^^^^ very good!
I will have another look at that tube and post the results
Thx |
Lo-Fi Version | Time is now: February 22nd, 2025 - 1:08 AM |
