> S54 06D gearbox, is it an lsd?
post Dec 6, 2012 - 4:09 PM
miib14
Joined Sep 23, '11
From UK
Hi guys
picked up a spare box from a member on CCUK, (trans code on celica was S54-06D)...
just wanted to ask you guys to confirm if it is an lsd box?
thanks
★ 1993 Toyota Corolla Saloon ★
It's all about N/A Power ..... 184.1hp and 142lbft
post Dec 6, 2012 - 4:14 PM
richee3
Joined Jun 29, '08
From Denver
Since its not installed, the easiest way to check is to look where the axles sit in the trans. If there's a thin bar and you can see through to the other side, it's an open diff. Yours looks like it has LSD.
Edit: how many miles are on the trans?
This post has been edited by richee3: Dec 6, 2012 - 4:16 PM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Dec 6, 2012 - 4:45 PM
miib14
Joined Sep 23, '11
From UK
i think the tranny had about 90k on it, but the 3rd / 4th gear syncro has gone (cant remember which one lol)
post Dec 6, 2012 - 4:59 PM
Rusty
Joined Nov 5, '07
From New Zealand
yes S54-06D is LSD gearbox code
post Dec 6, 2012 - 5:10 PM
miib14
Joined Sep 23, '11
From UK
but is the box?
it could have been swapped out, just wanted to confirm tbh
post Dec 6, 2012 - 5:43 PM
richee3
Joined Jun 29, '08
From Denver
Yes. The first picture is my S54 with an open diff, the second picture is my S54 with LSD.
With 90,000 miles on the transmission, I'd be worried about the health of that LSD. Helical LSD's wear out and start acting like an open diff between 60-90,000 miles. Sticking it with your 3S may be just a minor upgrade without refreshing the differential. Luckily, you'll be opening up the trans to replace the syncros anyway.
This post has been edited by richee3: Dec 6, 2012 - 5:58 PM
1998 Celica GT-
BEAMS Swapped.
post Dec 7, 2012 - 5:49 AM
miib14
Joined Sep 23, '11
From UK
thanks for that mate.
as im going to be opening up il get everything done..
post Nov 2, 2013 - 10:37 AM
Alan
Joined Jan 23, '05
From Malta
Hey guys I just realised that my s54 is and s54-06D I also purchased and e153 gearbox because i thought my s54 was non LSD will the shafts of the S54 fit my e153 tranny or do i need to buy mr2 iners and st185 outers anyway?
also how much power (tourqe) can the s54 06D tranny hold?
Does any one know?
post Nov 3, 2013 - 2:04 PM
Syaoran
Joined Jan 4, '12
From US
helical LSD: behave like an open diff when one wheel is totally unweighted, but "never" wear out, and generally are quieter and have easier driveability
Clutch type LSDs wear out. Gear-type LSD don't. Their only "wear" is a failure that breaks the gears.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Nov 12, 2013 - 5:52 AM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Where do you find the tranny code anyways?
post Nov 12, 2013 - 8:43 PM
Rusty
Joined Nov 5, '07
From New Zealand
on the chassis plate in the engine bay - non usa though
the Japanese/nz new ST204 are S54-02A, so I'd assume it would be the same
post Nov 13, 2013 - 1:06 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Rusty @ Nov 12, 2013 - 5:43 PM) *
So what about the usdm ones?
post Nov 13, 2013 - 1:31 AM
Rusty
Joined Nov 5, '07
From New Zealand
well yours are open diff so has to end with an A.
My guess is S54-02A
post Nov 18, 2013 - 2:09 AM
azn87
Joined Aug 2, '06
From bay area
are these located on the fire wall or the transmission it self????
Lo-Fi Version Time is now: November 22nd, 2024 - 7:57 PM
