Passenger side air vent |
Dec 7, 2012 - 9:38 PM |
Enthusiast Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
How do I take this thing off? I tried prying and pulling but it does not come off!
-------------------- God made man....
Everything else... Made in China |
Dec 7, 2012 - 10:10 PM |
Are you taking out your dash? The vent doesn't need to come out for that. So far as I can tell, it was never intended to be removed at all.
Dec 8, 2012 - 12:52 AM |
No I'm ,not taking off the dash, just the vent on passenger side by the door.
Dec 9, 2012 - 11:43 PM |
Enthusiast Joined Nov 30, '12 From Ohio Currently Offline Reputation: 0 (0%) |
I took my dash off and let me tell you, that vent is held in by 4 clips. It is nearly impossible to remove. I believe 2 are plastic and two are metal. It is somewhat similar to the drivers side, but the tabs are much tighter. The ductwork for them as well as the defroster vent will be in the way as well. I only got mine out because I was changing out the airbag, so my dash was coming out.
I wish I took a picture of it to show you. (I somewhat documented my dash removal.) You get two clips squeezed and then the other side pops into place. I waited until I got the dash out. MUCH easier. This post has been edited by broderp: Dec 9, 2012 - 11:44 PM |
Dec 10, 2012 - 12:28 PM |
I took my dash off and let me tell you, that vent is held in by 4 clips. It is nearly impossible to remove. I believe 2 are plastic and two are metal. It is somewhat similar to the drivers side, but the tabs are much tighter. The ductwork for them as well as the defroster vent will be in the way as well. I only got mine out because I was changing out the airbag, so my dash was coming out. I wish I took a picture of it to show you. (I somewhat documented my dash removal.) You get two clips squeezed and then the other side pops into place. I waited until I got the dash out. MUCH easier. Thanks, I finally got it out. I forced it and I broke the 2 plastic clips on the bottom of the vent. I figured that it would be easier if I took off the whole dashboard but I'm not doing that just for a vent. I wish you could have took pics! -------------------- God made man....
Dec 13, 2012 - 12:37 AM |
Enthusiast Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
nic, what they look like from the back...where's the plastic and metal piece
Dec 13, 2012 - 12:04 PM |
nic, what they look like from the back...where's the plastic and metal piece I will take a pic later -------------------- God made man....
Dec 13, 2012 - 9:42 PM |
i got it out with a really small flathead without breaking any clips, when I had to take it out.
Dec 14, 2012 - 2:45 PM |
i got it out with a really small flathead without breaking any clips, when I had to take it out. Was the dashboard out of the car? Bottom Vent Top Vent -------------------- God made man....
Dec 14, 2012 - 4:54 PM |
Enthusiast Joined Aug 11, '08 From London Currently Offline Reputation: 7 (100%) |
Was going to say slide a card like a credit card you dont need at the top and bottom edge widest edge in and it'll pop out. However looking at the pics it looks too late.
Dec 14, 2012 - 5:48 PM |
Was going to say slide a card like a credit card you dont need at the top and bottom edge widest edge in and it'll pop out. However looking at the pics it looks too late. That was the broken one anyway. Time to hit the junkyard again -------------------- God made man....
Lo-Fi Version | Time is now: November 23rd, 2024 - 4:17 AM |
