Clock blew up now stuff won't work..., Fixed. |
Dec 8, 2012 - 8:33 PM |
Enthusiast Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
So I was changing all my lights leds on the interior after I had just finished my trans swap and we plugged the clock back in and noticed it wasn't working. So we took it out and noticed it was blown. After this my lights wouldn't come on unless the car was cycled to run and the door sensor started acted up. Right after that the interior lights stopped working (courtesy, map, and trunk). Any idea as to what it could be?
Edit: Found a fuse, wasn't blown but was on its way out. This post has been edited by travisxcore: Dec 10, 2012 - 11:28 PM |
Dec 8, 2012 - 8:37 PM |
Did you put the ground strap back on the transmission? Ground issues can cause some funky problems.
Dec 8, 2012 - 8:57 PM |
I put them back in the best place I could remember they went...
I never noticed until now but my seatbelt light is out too (my seat has been unhooked from the sensor for years). I just hooked up my subwire and cleaned the terminal a bit and now they'll flicker but won't work. My battery cables have seen better days and aren't exactly clean so maybe that could cause it? |
Lo-Fi Version | Time is now: January 10th, 2025 - 6:19 AM |
