> Replace rear windshield wiper fluid pump?
post Dec 13, 2012 - 8:20 AM
aspen
Joined Nov 29, '07
From Colorado
The rear windshield wiper doesn't spray washer fluid anymore...And I get no noise when I try.
I'm betting the pump has gone out, as it's otherwise on the same fuse as the front and rear wipers and the front sprayers, right?
Anyone know anything about replacing it? Maybe part number?
2019 M2, 2005 S2000, 1997 4Runne
post Dec 13, 2012 - 9:48 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
i believe it is pretty easy. just under the hatch plastic. toyodiy.com is a good parts database.
post Dec 13, 2012 - 10:45 AM
seanb
Joined Aug 1, '11
From Illinois
Here is a page with the Toyota part #.http://www.toyodiy.com/parts/p_U_1995_TOYOTA_CELICA_AT200L-BLPSKA_8503.html
It looks like with a quick search you can get it for about $50-$60. However, I would make sure yours is truly toast first. It is easy to get to, just behind the front passenger
wheel well plastic. You can then inspect it to see if there is just dirt in the line. I would check your local junkyard before you spring for a new one. I pulled one from the yard for a forum member a while back and it worked great. And it was only $5.
The part stores have aftermarket brands for $10-$15, but these are universal type and make take some rigging to get them to fit. Hope this helps.
post Dec 16, 2012 - 8:27 PM
trdproven
Joined Aug 2, '05
From Guam
before you buy a pump, just realize first that these things get clogged. seen it happen twice to mine. was never the pump. I just used compressed air and now it works.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 24, 2012 - 12:54 PM
ricochet1490
Joined May 3, '11
From Ohio
It's 1 pump!!!!!!
look at your washer fluid bottle. At the bottom of the tank, the pump exists. Off the pump you'll be able to follow your lines through the right side fender. If you remove your wheel and fender plastic you'll see them go under the fender and through the right side of the car beside the firewall for the rear, and up to the hood for the front. I bet you have a clogged line/broken line as well.
The pump is fine, it just changes an internal flap I believe to direct fluid to either the front or the rear.
Lo-Fi Version Time is now: December 4th, 2024 - 10:35 AM
