Enthusiast ![]() Joined May 16, '10 From california Currently Offline Reputation: 1 (100%) ![]() |
going on a different set up
racepak 250-ds-udxrp comes with harness and sensors no problem working fine will include bracket for the ae86 asking $700 paypal is gtnicolas@yahoo.com get rid of those gauges working fine 714 574 0555 paypal is gtnicolas@yahoo.com This is a RACEPAK UDX Replay Dash. Given the popularity of replay and recall gauges, the UDX Replay Dash goes one step further by providing the ability to replay up to 10 minutes data, while also functioning as a full featured LCD display dash. The UDX Replay dash includes a wire loom and sensor for engine RPM, Water Temperature, Oil Pressure and Battery voltage. Sensors for displaying other sensor inputs must be purchased separately. UDX dashes are capable of displaying up to 21 different functions. There are five numeric displays, plus the engine RPM sweep bar, on each of the four screen pages. Scrolling from one page to the next is accomplished with the push of a button. The 7.25 x 2.62 LCD screen is backlit for night time operation. Each dash has output for a shift light, and shift point programming is done right on the screen. Warning lights are located on each side of the display screen. You have the ability to assign these high or low threshold alarms to your choice of monitored functions. The buttons at the bottom of the panel are used to scroll through the screen pages as well as to activate various functions. Additional sensors can be added by using the popular individual V-Net sensor and modules. Overall dimensions of the UDX bezel are 4.0 tall and 10.2 wide. It will stand out .750 from the mounting surface. The dash can be mounted against any flat panel which permits a depth of 2.00 inches behind the mounting surface for clearance of the dash and its rear mounted V-Net cable. The dash weighs a mere 1.3 pounds. ![]() racepak by nakahachi, on Flickr |
Lo-Fi Version | Time is now: February 23rd, 2025 - 9:23 PM |
