> CEL on but can't get code
post Dec 15, 2012 - 5:36 PM
rivs
Joined Jan 27, '08
From Mass
I have a 95 st and it is now running very rough and misfiring. it won't go about 3000rpm as the ecu cuts the fuel. I have a check engine light, but when I short the e1 and te1 pins nothing happens. Is there another way to get the code?
post Dec 15, 2012 - 8:22 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
do you turn the key to the on position when you do this?
Te to e1 is what you are supposed to jumper, so it should be working for you
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Dec 15, 2012 - 8:25 PM
rivs
Joined Jan 27, '08
From Mass
QUOTE (Smaay @ Dec 15, 2012 - 8:22 PM) *
When I turn the key to the on position, the check engine lights stays solid
post Dec 15, 2012 - 11:20 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
something is wrong then. are you sure you are jumpering the right terminals?
post Dec 15, 2012 - 11:46 PM
rivs
Joined Jan 27, '08
From Mass
QUOTE (Smaay @ Dec 15, 2012 - 11:20 PM) *
Yeah I'm sure they are the correct terminals. I even tried directly on the ecu to rule out any wiring issues and still get the same result. So I think my ecu is shot frown.gif
post Dec 16, 2012 - 1:05 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
that is possible. not common bit possible
post Dec 16, 2012 - 12:00 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Maybe she'll give it up after dinner and a movie?
Try TE2 and E1. TE2 is the advanced diagnostic port.
post Dec 16, 2012 - 3:00 PM
rivs
Joined Jan 27, '08
From Mass
QUOTE (Special_Edy @ Dec 16, 2012 - 12:00 PM) *
Haha I wish that's all it took! I tried TE2 and E1 still no dice, just a solid check engine light.
post Dec 16, 2012 - 3:07 PM
Box
Joined Feb 23, '12
From Warrior, AL
Code scanner. Advanced Auto Parts and/or Autozone does free scanning.
2001 Miata LS 5-speed
post Dec 16, 2012 - 5:36 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (Box @ Dec 16, 2012 - 1:07 PM) *
I took my car to AutoZone to get a free scan and they said they don't do it no more. At least the ones in Cali don't do it no more. I don't know about other states and stores.
This post has been edited by ILoveMySilly97: Dec 18, 2012 - 3:15 PM
post Dec 18, 2012 - 11:56 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
that only works on ODBII cars. this is a 95 so its ODBI
post Dec 18, 2012 - 12:03 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (Smaay @ Dec 18, 2012 - 10:56 AM) *
There are still OBDI scanners.
post Dec 22, 2012 - 1:14 PM
rivs
Joined Jan 27, '08
From Mass
I figured I would post and update in case this happens to anyone else. After replacing my ecu the car runs great. No CEL and no misfiring nothing.
So long story short, if your pre96 celica throws a CEL and you can't retrieve it and all the sensor and voltages check out at the ecu, then it's time to replace the ecu.
Lo-Fi Version Time is now: December 4th, 2024 - 11:03 AM
