22 Pages V   1 2 3 > »
> ST205 Total Rebuild, Something a bit different
post Dec 16, 2012 - 1:28 PM
Nial
Joined Aug 25, '08
From England
I was certain I started a build thread on here, but for the life of me I can not find it so forgive me if I start again and its old news.
About a year and a half ago my current GT4 failed its yearly inspection (MOT) with rusty sills, they were fixed and it subsequently passed but it set alarm bells ringing in my head that the poor things days were numbered.
I decided that I would buy a shell and swap everything onto it. so I hunted for a reasonable shell to start work on.
While I was looking, I had to extend my garage. I only had a single car garage so not enough space to work or store stuff.
So I decided to extend my garage backwards a bit
Work started.
and after a few weeks, finished ;0
About the same time a shell turned up, well it was sold as a shell, but it was more or less a complete car minus the engine and gearbox.
It was in good condition with no rust, even the interior was in pretty much spot on condition, not that I need much of it
I set to wrok more or less straight away
First job was to strip everything off the car
everything went, all the looms, glass, suspension the works
Next job was to remove the sound deadening material
it then went outside for a thorough jet wash go get rid of all the years of crap
As I was moving the battery to the inside I could remove the battery tray
which I did
Next up I needed to get to the bottom of the car....this was going to require some ingenuity.
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
post Dec 16, 2012 - 1:38 PM
Nial
Joined Aug 25, '08
From England
I was going to have to make my own rotisserie.
So ack off to the wood yard, a few lengths of 2x4 and I made this
It was about now I realised two things. One I was going to have to learn to weld and two..my plans for this car were changing quite dramatically......a fancied making a cross between a rally car and a GT car...no idea how I was going to achieve this, but the seeds had been set in my mind and for once they stayed there.
So I rushed out and purchased a MIG welder....learning to weld was pretty easy to be honest, by no means as neat as the pros but not bad for a complete novice.
So I made a rotisserie
It fitted like a glove and worked perfectly
A quick look revealed the sills were pretty mangled
so I had to fix them up as best I could
At the same time I started blasting and painting with good old POR15 the subframes and suspension parts
The came out quite nice
did the prop shaft too, started a bit rough
came up well
also cleaned up the steering rack
and the alloy diff end plate....gave it a good polish
Next up I started the worst job I have ever attempted
post Dec 16, 2012 - 1:45 PM
Nial
Joined Aug 25, '08
From England
Tackling the stone guard on the bottom of the car.
I cant count the amount of drill & angle grinder wire brush attachments I have gone through.
it makes alot of dust and takes what seems like forever
slow slow work
this stage took about a month
at last, more or less done
I then painted it with more POR15
More or less at the time I was ready to slit my wrists due to constant wire brushing the roll cage turned up (I still havnt finished under the car....I am going to get the rest sand blasted....i just cant face it any more
A brief test fitting and I was starting to get excited.....I was going to have to break out the welder again smile.gif
post Dec 16, 2012 - 1:54 PM
Nial
Joined Aug 25, '08
From England
First job was to add some strengthening to the top of the rear suspension tops, so i removed the odd metal bracing off them (i think its used to just hold the rear plastics in place?)
I then made a template
and then a metal top (3mm mild steel)
and one for the other side
Once I had welded these to the car it was time to start getting the roll cage in
I filled the aerial hole whilst I was at it
Anyway, back to the cage, more bits turned up
this was starting to get serious
this ties in the rear sub frame to the cage, helps keep things stiff
nearly there
as you can see my welding isnt great, but as its more or less the seond thing I have ever welded in my life i was mildly pleased with it
Done
i had decided that I didnt want a full cage, at the end of the day it will be just a road car so getting in and out easily is a priority
Next up I decided it was about time to learn how to cast new metal parts, as for what I had in mind the parts do not exist, I was going to have to make them.
post Dec 16, 2012 - 1:59 PM
Nial
Joined Aug 25, '08
From England
I was going to have to make myself a mini blast furnace...and learn how to cast metal
I needed these
I turned the bin into a furnace with the use of some fire cement
fill it with charcol, attach a heat gun, ignite and stand back
I made a vessel from a spare piece of square tube...it gets pretty hot
hot enough to melt alloy
I still needed to learn how to make sand moulds so stopped there for the time being, I will pick that up again later.
post Dec 16, 2012 - 2:06 PM
Nial
Joined Aug 25, '08
From England
Taking a long look at my roll cage, I was not happy with the welds. so i decided to dress them, smooth them out, add a little body filler and make them smooth
started looking much better although I did have to remove the main hoop cross member for access
dont worry its not going to be that colour, thats just filler primer
at the same time I cleaned up the floor and primed that ready for paint
the boot aswell....I also welded the cross member back in
Next up was the seam sealer, so I masked off the areas I was going to apply it to
then applied the U-Pol grey stripe seam sealer (nasty stuff)
and that is about where I am up to today. Just been out into the garage to remove the masking tape. it looks a bit messy, but when its primed over the top you can hardly tell its there. I will add more pictures when I have taken them.
I will update when I get a chance but I work pretty slowly so dont expect much.
hope I havnt bored you to death
more to come
Nial
post Dec 16, 2012 - 2:19 PM
Great job.
That's a ton of work, impressive.
post Dec 16, 2012 - 10:18 PM
Ted95
Joined Mar 8, '09
From Westport, MA
Not your everyday build, excellent job so far man.
st205 powered ss3 coupe
post Dec 16, 2012 - 10:43 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
super diy!!
エキサイティングカーレーシングチーム!
post Dec 17, 2012 - 12:47 AM
QUOTE (Nial @ Dec 16, 2012 - 2:06 PM) *
Quite the contrary. Excellent.
post Dec 17, 2012 - 5:06 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
post Dec 17, 2012 - 5:32 AM
Nial
Joined Aug 25, '08
From England
QUOTE (malpaso @ Dec 17, 2012 - 5:06 AM) *
Cheers. means alot from a fellow faffer smile.gif I hope the end result looks as nice as your car.
This post has been edited by Nial: Dec 17, 2012 - 6:05 AM
post Dec 17, 2012 - 6:28 AM
Edser
Joined Jul 5, '12
From Barcelona
Looks great! It'll be like new!
Just one thing I was wondering about. I don't know much about roll cages, but it is my understanding that if you put in racing seats and harnesses you'll need a horizontal shoulder height beam to attach the harnesses to (the reason being, to avoid spinal compression in the event of an accident). Have you considered this?
post Dec 17, 2012 - 6:41 AM
Nial
Joined Aug 25, '08
From England
QUOTE (Edser @ Dec 17, 2012 - 6:28 AM) *
I will be using normal belts, If I want to use a racing harness I will attach it to the rear strut brace as the Rally Cars did. as they lie within the tollernece angles to avoid such injuries.
post Dec 17, 2012 - 10:36 AM
richee3
Joined Jun 29, '08
From Denver
Great work so far! I can't wait to see where this goes.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Dec 18, 2012 - 4:45 AM
S8S8
Joined May 9, '09
From Brisbane, Australia
Nice work! Can't wait to see the finished product.
post Dec 18, 2012 - 2:23 PM
Nial
Joined Aug 25, '08
From England
I dont know if you guys like small regular updates, or big updates every yew months?
well here is a little update. I just about finished the seam sealer today but to show you a comparison, one side of the car is finished and the seam sealer has been primed, the other side it has just been applied.
Left side it has just been applied, right side has had two coats of seam sealer and had primer sprayed over the top. I am pleased that you can hardly see anything despite the fact it will all be covered over with sound mat.....just because you cant see it dosent mean it cant be right.
cheeky shot of the cage
This post has been edited by Nial: Dec 18, 2012 - 4:02 PM
post Dec 18, 2012 - 6:00 PM
enderswift
Joined Jul 12, '08
just because you cant see it doesn't mean it cant be right
This is how I know this thread will be good
post Feb 25, 2013 - 3:47 PM
Nial
Joined Aug 25, '08
From England
I have been busy recently, but have found some time to spend on this project.
I stripped down the petrol tank
gave it a good paint
the obligatory walbro fuel pump
all back together with some stainless steel bolts
rejuvenated the fuel tank straps
started rebuilding the rear axels
managed to rescue the rear brake disc backing plates
they came up well
Found a product called Deox C which is great at getting rid of rust, bought the rear hub carriers up a treat
and I got alot of bolts zinc plated
and the door catches chromed
things are starting to go back together now, the rear subframe and suspension parts are all half built, just waiting for the paint on the rear hubs to dry and cure and they can go back together, need some snap rings for the rear axels, then they can go back on. Rear diff can be completed tomorrow if I get time.
post Feb 25, 2013 - 4:10 PM
paulgtt
Joined Sep 10, '08
From UK
absolutely epic Nial, top work.
Lo-Fi Version Time is now: November 25th, 2024 - 12:09 PM
