Quick Ratio Steering Rack? |
Dec 18, 2012 - 4:18 PM |
Enthusiast Joined Sep 27, '10 From pittsburgh Currently Offline Reputation: 4 (100%) |
Anyone ever heard of one for a 6th gen, or anyone ever try and make one using rack/pinion gear from another vehicle?
-------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD -10 F150 Always buying stock wheels... PM me if interested in selling. |
Dec 18, 2012 - 5:54 PM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
apperently the SS-III is a quick rack
Dec 18, 2012 - 8:50 PM |
can u adapt one from another car?
Dec 19, 2012 - 2:59 PM |
modify the stock one?
Dec 19, 2012 - 7:39 PM |
Yeah, I do have a spare rack.... but it's not very simple to just modify. The gearing has to be changed, which is built into the rack and pinion.
Unless i found a replacement that fit, not sure it would work. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
Dec 20, 2012 - 3:17 PM |
Could you not remove the OEM piece from a spare, weld it over and then recut it?
If not, should be able to have it machined pretty easily out of a blank and then rethreaded on the ends. OEM vw piece on the left, Quick on the right. |
Dec 21, 2012 - 2:44 AM |
apperently the SS-III is a quick rack i heard the ratio being different for superstrut and mcpherson vehicles. Thats what one member told me who went from mcpherson to superstrut suspension. his name is hardblacktop93 -------------------- Group buy to replicate Narrow E series transaxle parts
Dec 24, 2012 - 12:54 PM |
Enthusiast Joined May 21, '12 From OC Currently Offline Reputation: 0 (0%) |
Anyone ever heard of one for a 6th gen, or anyone ever try and make one using rack/pinion gear from another vehicle? I used one like this on my BMW, works great as long as you have power steering. http://www.speedwaymotors.com/Small-Body-2...kener,2030.html |
Dec 26, 2012 - 6:36 PM |
You will have bumpsteer issues if you put in a different geometry rack out of another vehicle.
I forgot the exact details but the tie-rod length has to be specifically proportional to the control arm length. If its too long or short the wheels will turn toe-in/toeout when you go over bumps(bumpsteer). The tierods must also be on a perfect axis with the roll-center of the suspension or some other suspension geometry point(I cant remember). This is one of those things where the oem manufacturer knew exactly what they were doing when they designed it and without proper schooling all any of us can do is guess. The idea of modifying the gear ratio of the rack and pinion gear sounds practical, maybe not cheap though. |
Dec 26, 2012 - 9:12 PM |
i had once let someone drive my GT4 who had a regular celica, the first thing he noted was that the car turned alot more with the same steering input.
I hadn't really noticed myself as i had an SS-III before that -------------------- Mike W
Dec 26, 2012 - 11:03 PM |
turns faster yes, but doesn't turn as much, suspension reasons my guess
Dec 27, 2012 - 2:57 AM |
AWD binds up anyways, but i think in general theres a reason why high speed cornering cars are poor at making low speed turns, like some kind of tradeoff
though no st20* celica has ever been praised for its turning radius, superstrut or not -------------------- Mike W
Dec 27, 2012 - 8:29 AM |
Anyone ever heard of one for a 6th gen, or anyone ever try and make one using rack/pinion gear from another vehicle? I used one like this on my BMW, works great as long as you have power steering. http://www.speedwaymotors.com/Small-Body-2...kener,2030.html This is interesting. Might have to try a 1.5x quicker. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
Dec 27, 2012 - 9:27 AM |
This is interesting. Might have to try a 1.5x quicker. It's an easy install, just cut the steering column and add it under the dash. You'll need to keep the powersteering even with the 1.5:1 or your arms will get really tired by the end of a stage/session. I'm thinking about doing it to my Road Race Celica too. |
Feb 24, 2014 - 3:36 AM |
player is that picture of a ST205 superstrut ratio rack??
Feb 24, 2014 - 10:39 AM |
Enthusiast Joined Jan 26, '09 From Los Angeles Currently Offline Reputation: 1 (100%) |
Holy thread bump!
I was reading this thread like wtf does Steve want with this now haha -------------------- |
Feb 24, 2014 - 1:04 PM |
Feb 24, 2014 - 5:19 PM |
The vw after OEM stands for Volkswagen?
Feb 25, 2014 - 2:23 PM |
yes
Lo-Fi Version | Time is now: November 29th, 2024 - 6:34 PM |
