st182 transmission |
Dec 18, 2012 - 7:02 PM |
Enthusiast Joined Oct 24, '12 From Cyprus Currently Offline Reputation: 0 (0%) |
hey guys. just a quick question. i have an st202 with 3sgte rev3 engine and transmission from an st182. is the transmission of an st182 the same as an st185? if i buy a clutch kit for an st185 will it work on my car?
thanks in advance |
Dec 18, 2012 - 7:42 PM |
Enthusiast Joined Dec 28, '11 From GA Currently Offline Reputation: 0 (0%) |
The ST182 transmission is a S53 which is not the same as the ST185 stransmission (E151F)
To make the S53 mork with the 3S-GTE you will need the flywheel from a 3S-GTE and the clutch disc from a 5S-FE. |
Dec 18, 2012 - 8:05 PM |
The ST182 transmission is a S53 which is not the same as the ST185 stransmission (E151F) To make the S53 mork with the 3S-GTE you will need the flywheel from a 3S-GTE and the clutch disc from a 5S-FE. thanks for the answer fussellbug. but why do i need to use a clutch from 5S-FE? |
Dec 19, 2012 - 1:33 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
The spline is much bigger on the "E" series trannies vs the "S" series. So the clutch disc won't interchange. If you install the st185 clutch kit the s53 trans spline will be spinning around like a hot dog in a hallway. You can buy a 3sgte pressure plate and 5s clutch disc that would work. Or talk to doc tweak he carries competition clutches for swaps.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Dec 19, 2012 - 4:05 PM |
hehe hot dog in a hallway mmm can i know y i have to install a 5s clutch? im just curious
Dec 19, 2012 - 7:10 PM |
You cant install the 5s kit because the pressure plate wont bolt onto the 3s flywheel. Forgot to mention that the flywheels aren't the same. You can Call ACT clutch and have them do a custom setup for you. 5s clutch disc 3s pressure plate.
This post has been edited by bccentaur3: Dec 20, 2012 - 8:53 AM -------------------- 98 Celica gt red- totaled deer
Dec 20, 2012 - 7:29 AM |
can i just install a st182 clutch and a Fidanza flywheel?
Dec 20, 2012 - 8:13 AM |
Enthusiast Joined Dec 16, '11 From The Netherlands Currently Offline Reputation: 5 (100%) |
like i said on Facebook, yes you can.
my old setup also had a st182 transmission with a Fidanza flywheel. |
Dec 20, 2012 - 9:00 AM |
Find out the transmission code that you have for the st182. If its an S53 transmission you cannot just use a clutch kit meant for a gt-four or mr2 turbo. Now you can get fidenza flywheels for the enigne you have. Just order a clutch kit for a st182 problem solved. Just realized st182 came standard with a 3sge.
Dec 21, 2012 - 5:40 AM |
where can i look for the code guys?
Lo-Fi Version | Time is now: December 3rd, 2024 - 9:40 PM |
