My new Celica ST205 GT4 |
Dec 28, 2012 - 7:36 PM |
Enthusiast Joined Jul 13, '11 From Lincs, UK Currently Offline Reputation: 0 (0%) |
Hello,
Pretty much a lurker of the forum but thought I would share. After a very short period of no Gen 6 ownership I bought another GT4. It had pretty much the spec what I wanted to get my previous car to and was a very nice example so it made sense. I might get slated for buying a pre-modified car but I don't care to be honest! 1994 Celica ST205 GT4 JDM Spec: Engine etc: Garrett Ball bearing GT3071r kit (4" intake version) with Tial external wastegate, 3" downpipe and screamer pipe Apexi PFC and Commander Mapped by Ryan G from 2Bartuning Sard 800's Ported manifold 3" Japspeed stainless steel exhaust Blitz SBC -ID III -Spec R and Blitz power meter Innovate wideband sensor with afr gauge Walbro 255 fuel pump Straight intake with big K+N filter Magnecor KV85 8.5mm leads Evo 8 fmic Blitz bov Omex rev limiter/launch control operated from clutch pedal switch Suspension/brakes: BC coilovers Grooved Toyota front discs,ebc rear discs and yellow stuff pads front and rear Whiteline adjustable rear arb Hel brake hoses Cooling: RTP alloy radiator Slim fans with override switch TRD thermostat Turbo pre rad cooler Mocal oil cooler Mocal thermostatic sandwich plate Mocal braided hoses C-One cooling panel Swirl pot and header tank system Silicone hoses Interior: Momo steering wheel Momo alloy gear knob Alloy pedals White Dials switchable from green to blue Full leather interior Carbon fibre dash bits Exterior: Carbon fibre wind deflectors Carbon fibre door sills TRD side skirts and side spats De-tangoed Later lights Spoiler riser blocks Cat1 Alarm and immobiliser |
Dec 28, 2012 - 8:55 PM |
Enthusiast Joined Sep 22, '12 From England Currently Offline Reputation: 0 (0%) |
nice , good to see another uk owner as well
Dec 28, 2012 - 10:32 PM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
very nice car!
I believe the original C-ONE cooling panel didnt have a gap in it...might be wrong though. mine doesnt. -------------------- |
Dec 29, 2012 - 5:56 AM |
Thanks guys
I wouldn't know if it was a genuine one or not to be honest - as far as I am concerned it's a bit of sheet metal What gap do you refer to? Next plans are to get a forged engine if I can raise the funds and decide what I want...as running 1.6 bar on the stock internals is asking for something to break (even though it has had this setup for about 2 years) Alex This post has been edited by alex1981: Dec 29, 2012 - 5:56 AM |
Dec 29, 2012 - 7:23 AM |
Enthusiast Joined May 9, '09 From Brisbane, Australia Currently Offline Reputation: 0 (0%) |
Looks awesome. Nice purchase.
It had pretty much the spec what I wanted to get my previous car to and was a very nice example so it made sense. I might get slated for buying a pre-modified car but I don't care to be honest! I know what you mean. I prefer to buy unmodified too, but given we all know how much money you lose when modding a car, it's probably not a bad idea to buy one that someone else has already lost a heap of money on! -------------------- |
Dec 29, 2012 - 7:39 AM |
Thanks
Indeed. Don't get me wrong - I love the process of modifying from initial research to the testing - but you do end up realising how much money you throw at things in the end. |
Dec 29, 2012 - 8:01 AM |
1,6 bar, and no smoking? you sure thats not forged? my rings went at 1.7 bar complete cluster****
my panel says C-ONE on the left and there is no gap near the hood release hooky thing, it is a full cut out rectangle -------------------- |
Dec 29, 2012 - 8:11 AM |
No smoking, turbo picks up hard from low revs all the way through to the redline (which has been raised a bit) - it's not laggy either - the power is there whenever you want it. Engine temperatures stay low (infact, lower than my previous Celica when it was stock) and ECU tells me the knock never goes too high The engine is not forged - as far as the previous owner is aware (the first to start properly modifying, so unlikely the previous owners would forge it) it is completely untouched stock internals.
Ah fair enough, perhaps mine is a copy C-One then. Ah well |
Dec 29, 2012 - 8:29 AM |
I never understood why they left a gap in the replica I remember em from the group buys... i use mine as a small tool bench when working on the car hehehe
Dec 29, 2012 - 10:11 AM |
Enthusiast Joined Aug 11, '08 From London Currently Offline Reputation: 7 (100%) |
hi Alex. Ray here at RTP. Did yiu ever get that dynoed to see what figures you got with its current setup?
Also i know you said yiu bought it at that spec but do you know wuo did the plumbing of the manifild and screamer? |
Dec 29, 2012 - 10:17 AM |
Enthusiast Joined Mar 4, '08 From Aldershot,Hampshire Currently Offline Reputation: 0 (0%) |
Looks like a car belonging to a old GT4OC member from Nottingham area
-------------------- Women are snakes with tits
Dec 29, 2012 - 10:27 AM |
Correct Johny
Ray: No idea who did the plumbing for the screamer and manifold. I could ask James if you are not in touch anymore? I assume you are where the rad came from then? Not had it Dyno'd. Anyone want to make a guesstimate? |
Dec 29, 2012 - 10:52 AM |
I wonder why they kept the stock exhaust manifold. its such a pain to work with putting an adapter since its a tight fit with a large rad.
atleast 1/4 inch from fans to turbo in my case This post has been edited by Neon90424: Dec 29, 2012 - 10:53 AM -------------------- |
Dec 29, 2012 - 11:02 AM |
What manifold would you suggest, then? Or is it a case of a custom made one?
Dec 29, 2012 - 11:20 AM |
Thinking about what you said...I assume you have a stonking great big turbo then? I have a fair bit of room.
Dec 29, 2012 - 11:35 AM |
Nipped out and took an interior shot. Sorry for the bad lighting - the weather here in the UK is dark and horrible :\
Some say the Celica interior is drab. I disagree and also find it to be one of the comfiest places to be. This post has been edited by alex1981: Dec 29, 2012 - 11:37 AM |
Dec 29, 2012 - 12:53 PM |
Standard manifold is strong and wont break and if ported can make good numbers , if you are going aftermarket id recommend a full race version - Tuning Developments in manchester area can supply these.
When James had this i thought it was best silver 205 by a country mile - just needed projector headlights to finish it off. At one point it had a black rear number plate surround to break things up at the back - i sent it James FOC as i had a nice carbon version -------------------- Women are snakes with tits
Dec 29, 2012 - 1:10 PM |
As johny said. unless youre running very big hp the stock cast manifold actually out perform many ss manifolds out there.
Yes Alex the rad is from me. You have a very sensible even and supported setup there. This post has been edited by yellowchinaman: Dec 29, 2012 - 1:11 PM |
Dec 29, 2012 - 1:40 PM |
Ah fair enough. What power do you think the stock manifold will take?
Hmm black rear surround had never occurred to me and not seen one. Chinaman - the rad is decent quality and with the other bits runs at a steady temperature. Could you tell me/pm a price for another exactly the same - a friend has just bought a GT4. |
Dec 29, 2012 - 2:09 PM |
Enthusiast Joined Jul 10, '08 From Newmarket, Ontario, Canada Currently Offline Reputation: 1 (100%) |
Beautiful GT-Four!
-------------------- - 1994 ST205 GT-Four WRC
- 2000 Celica GTS (Swap in progress) |
Lo-Fi Version | Time is now: November 25th, 2024 - 9:04 PM |
