> How to sand/prep/paint ABS plastic., Need help
post Jan 2, 2013 - 1:16 AM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Some of you may know that I was going to get a paint job but due to me purchasing a new set of Enkei RPF1. The new paint job is put on hold til summer maybe. I decided to just repaint the GT4 rear splitters that I have myself. Since it doesn't look too hard to attempt. I never done any kind of sanding or painting or yea. Just a FYI I sucked at art. LOL! But to get to the point. I need help to repaint them. As of right now they are RED and want to repaint them with Silver 119. They are OEM and not replicas.
My questions:
What grade sand paper? Wet or dry sand?
What's the best primer for ABS plastic?
Need help on this DIY repaint.
Specs:
GT4 Rear Splitters
OEM ABS plastic material
Currently still have the original paint on it I believe
Slightly scraped but no holes. See pics.
Pics:
This post has been edited by ILoveMySilly97: Jan 2, 2013 - 1:18 AM
post Jan 2, 2013 - 2:00 AM
Box
Joined Feb 23, '12
From Warrior, AL
Wet-sand the entire time. Start with 400, then 600, and finally 800. Duplicolor makes a product called Adhesion Promoter, which is a clear primer. It works great for plastic body pieces. Then your colour coat, and follow with clear coat. Let it cure for at least a week, then proceed with wet-sanding with 2,000 and follow up with rubbing compound and polishing compound. Wash and wax then apply to car.
Side note, you can use chemical paint peelers safe for plastics that'll make life a lot easier. It's a lot easier to paint a completely bare surface, versus trying to get everything level by painting over old paint. Also, if you know some place with a soda blaster that'd be ideal.
This post has been edited by Box: Jan 2, 2013 - 2:03 AM
2001 Miata LS 5-speed
post Jan 2, 2013 - 11:52 PM
ILoveMySilly97
Joined Mar 8, '12
I'm guessing the sand paper can be bought from HomeDepot? Does it matter what kind of sand paper I use? How far in should I sand it down. Until most of the red paint is gone?
post Jan 3, 2013 - 3:27 AM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (ILoveMySilly97 @ Jan 2, 2013 - 10:52 PM) *
I'd suppose you could. Wal-Mart carries 3M Automotive sandpaper meant for wet sanding. Sand it until the surface is even and smooth. Then can use primer to make a level surface for paint.
Box
Joined Feb 23, '12
From Warrior, AL
post Jan 8, 2013 - 12:09 AM
ILoveMySilly97
Joined Mar 8, '12
Makes sense. I believe I saw some at walmart. I'll head out and start buying and ordering the things I'm going to need for this project. Thanks for the info!
post Jan 8, 2013 - 1:08 AM
Box
Joined Feb 23, '12
From Warrior, AL
Welcome. Glad could be of some help. Remember, it's all in the preparation.
post Jan 18, 2013 - 7:41 AM
doctavic
Joined Jun 5, '12
From NJ
I'm going to follow this and paint my splitters this weekend. Any recommendations on what kind of paint to use?
post Jan 18, 2013 - 8:36 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
As stated above I'd start with 120-220 grit wet-dry sandpaper. The rougher it is the faster it will remove material. But once your done removing material you need to smooth it out. After 120 use 220 or whatever is closest. Then 400, then 600 or 800 but it is usually recommended to finish with 800. Use a block sander, if you use your hands to do most of the sanding you WILL create an uneven surface. Once you apply gloss the surface will appear wavy and bumpy if you dont use a block. They sell blocks that flex and bend over curves, use this for as much of the visible surface as possible.
I would also recommend sanding something that size in the tub or sink if possible. The wet/dry sandpaper is waterproof, so you can apply a steady stream of water or submerge the piece while sanding. The purpose of wet sanding is a) to greatly reduce the amount of effort by reducing friction; b) to keep the sandpaper clean of sanding dust, so that it will last MUCH longer; c) to eliminate the dust that would get everywhere in the room you are sanding in, instead it will get trapped in the water.
Follow the instructions for the paint. Whatever manufacturer you buy the basecoat/clearcoat(or if its a single coat) from will have a data-sheet available for their paint. The manufacturer has spent countless hours and dollars developing their paint, and all of their recommendations for prep work, mixing with thinner, optimal spraying conditions/techniques and finishing the final coat will be included in the datasheet. If you read and follow the datasheet you will have an excellent coat of paint, if you dont follow the datasheet it will come out like crap(this is your first time). Call the company or visit their web site for the datasheet, its not the paragraph on the can.
DO NOT USE A PRIMER AND BASE/CLEAR COAT OF DIFFERENT BRANDS. Use the same brand, they are designed to chemically adhere to each other. Once you have purchased the topcoats you can then use the same manufacturers recommended primer for best results
This post has been edited by Special_Edy: Jan 18, 2013 - 8:44 AM
post Jan 18, 2013 - 9:11 AM
doctavic
Joined Jun 5, '12
From NJ
QUOTE (Special_Edy @ Jan 18, 2013 - 9:36 AM) *
Thanks so much, this is really good information. I'll let you know how it turns out!
post Apr 19, 2013 - 6:25 PM
ILoveMySilly97
Joined Mar 8, '12
One last question before I start spraying. Im going to spray a layer of the clear adhesive promoter then spray on top of that white primer. Is that durable? Or should I just skip the white primer and spray on my silver paint?
post Apr 19, 2013 - 6:43 PM
doctavic
Joined Jun 5, '12
From NJ
QUOTE (ILoveMySilly97 @ Apr 19, 2013 - 6:25 PM) *
I used the primer, but I think it would come out the same without it.
post Apr 19, 2013 - 7:02 PM
ILoveMySilly97
Joined Mar 8, '12
Ok. Thanks doctavic.
post Apr 19, 2013 - 8:13 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Apr 19, 2013 - 10:17 PM
ILoveMySilly97
Joined Mar 8, '12
Yea, ima run to O'Reilly on Sunday morning to get the dupli color primer but which one should I get? Like which type?
post Apr 20, 2013 - 12:16 AM
Box
Joined Feb 23, '12
From Warrior, AL
http://www.duplicolor.com/products/fillerPrimer/
post Apr 20, 2013 - 2:04 PM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
if the red is factory paint, you will get a better bond to wetsand with 400/500/800 then use your primer and paint as the factory paint has the best bond you can get in most cases so its best to work on top of the factory paint for plastic parts. i just painted my front end with the dupli-color paintshop while it was cheap and worked ok, it can be pretty orange peely because it does dry fast due to it being lacquer, but i didnt have any issues with it. the primer i got was a very light gray color but, it did cover VERY well with 2 medium coats.(one of my fenders was a green/blue) metallic and i was painting it white and both fenders match(other one was factory white)..this is just my advice. good luck!
Lo-Fi Version Time is now: November 25th, 2024 - 9:34 PM
