Remove bearing snap ring?, What kind of tools to use? |
Jan 3, 2013 - 5:51 PM |
Enthusiast Joined Sep 9, '12 Currently Offline Reputation: 0 (0%) |
I'm replacing the wheel bearing.
Stuck on snap ring. How to remove it? Thanks for any advice. |
Jan 3, 2013 - 6:00 PM |
You need a pair of (large) snap ring pliers.
Jan 4, 2013 - 12:16 AM |
Jan 4, 2013 - 1:38 AM |
i just use needle nose pliers. remember to wear safety googles as they are under high tension when you compress the ring.
Jan 4, 2013 - 3:36 AM |
two flat head screw drivers will work if you don't have any
Jan 4, 2013 - 3:39 AM |
Enthusiast Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) |
two flat head screw drivers will work if you don't have any x2 i've used this method -------------------- 6gcHeroes:808hectortimmybatmandiegotigamak |
Jan 4, 2013 - 4:54 AM |
Jan 6, 2013 - 7:00 PM |
Lo-Fi Version | Time is now: December 2nd, 2024 - 1:04 AM |
