> 4age 20v clutch/flywheel, searched and found a little info. need more
post Jan 4, 2013 - 3:01 PM
TerBeau
Joined Nov 25, '08
From dillsburg pennsylvania united states
i bought a 4age 20v and im having a hell of a time finding freaking parts haha. maybe due to the japan only engine. any way, ive seen that the 7a flutch would work? is this true. and as far as flywheel options. how many bolts do the crank have for the 4age? i got timing belt, pully, water pump, and getting a .8mm head gasket from trd. but i want to put a new flywheel and clutch in before the installing proceeds. any help is sweet and greatly appreciaclub4ag isnt working at the moment or id look there too kindasad.gif
This post has been edited by TerBeau: Jan 4, 2013 - 3:04 PM
those with golf balls golf
those with real balls race
post Jan 4, 2013 - 3:15 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
why why why?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 4, 2013 - 3:34 PM
TerBeau
Joined Nov 25, '08
cuz cuz cuz... motor.. trans.. ecu. harness already switched to work on the celica.. ignitor, afm, external coil. and longer throttle cable for 500 bucks. an idiot would pass this up!
post Jan 4, 2013 - 3:38 PM
TerBeau
Joined Nov 25, '08
and its different. has potential for hp and can keep it a dd in the summer time! im not going bawlz on gains and ****. i want a bit more powa and keep it simple
post Jan 5, 2013 - 1:44 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
If you buy a lightweight flywheel off ebay any of the 4age 16V flywheels will work, but usually the seller will send you something that only the clutch on a 4AFE will fit on. If you get a light flywheel and clutch combo then usually you don't have to stress over the details. (The 4AFE clutch is a little smaller in diameter than the 4age 16V)
PM me if you are interested, I have a brand new lightweight flywheel with a 4AFE clutch kit that is mated on to my ST engine and transmission but has 0 Miles, since I have long abandoned the project.
post Jan 5, 2013 - 2:02 AM
TerBeau
Joined Nov 25, '08
QUOTE (soulshadow @ Jan 5, 2013 - 2:44 AM) *
pmed thANKS
Lo-Fi Version Time is now: January 10th, 2025 - 8:11 PM
