Enthusiast ![]() Joined Sep 9, '08 From Jamaica Currently Offline Reputation: 1 (100%) ![]() |
Hey guys,
Ive installed one of thos aem fuel pressure gauges on my dash and have it wired up, only thing is, I wonder where to tap the pressure sensor. Any tips on where anyone put theirs? I can make a part (like a "T" bracket) to put it anywhere pretty much, just wondering where is easiest so i can focus (by the regulator or by the entrance to the rail....or wherever else...) thanks. This post has been edited by Island_Racer: Jan 9, 2013 - 11:52 AM |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
you want the sensor in the rail before the regulator. you will have to play around with fittings to get something that works.
this is the banjo bolt that feeds the rail. if you can find a fitting that supports this banjo and also has an 1/8 NPT (your pressure sensor) then you should be good to go.
This post has been edited by Smaay: Jan 9, 2013 - 1:28 PM -------------------- 2001 Celica GT-S Turbo
so basically this....
http://www.ebay.com/itm/Russell-640700-Fue...bc2&vxp=mtr do you know the size banjo bolt (12X1.25??), so i can pull and replace same time? thanks man This post has been edited by Island_Racer: Jan 10, 2013 - 9:40 AM |
its either 10 or 12
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
12x1.25
may aswell get a fuel regulator too while your at it, will have the port for the gauge/sender -------------------- Mike W
Lo-Fi Version | Time is now: February 22nd, 2025 - 6:43 AM |
