> H E L P !
post Jan 12, 2013 - 9:45 PM
cajon
Joined Jul 22, '07
From Hendersonville,Tn.
Ive done about everything i know to do. Dr Tweek if you see this, ...help please. Ive done so much to this car, i dont know what else to do. Engine swap, new fuel filter/pump among other things. Heres what its doing. At idol, it runs like a top. But the second i put any kind of a load on the engine, it starts putting and sputtering. It was doing all of this befor the engine swap. Im completly out of ideas, aggravated, and need help. P L E A S E ! ! !
post Jan 12, 2013 - 9:56 PM
Neon90424
Joined Jan 19, '11
sounds maybe like a vacuum leak? maybe FPR vacuum isnt hooked up?
post Jan 12, 2013 - 10:02 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
tps?
what engine?
post Jan 13, 2013 - 12:08 AM
Box
Joined Feb 23, '12
From Warrior, AL
MAF or MAP sensor?
2001 Miata LS 5-speed
post Jan 13, 2013 - 4:20 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I 2nd the MAF or MAP sensor.
post Jan 13, 2013 - 4:54 PM
cajon
Joined Jul 22, '07
QUOTE (stephen_lee @ Jan 12, 2013 - 11:02 PM) *
tps?
what engine?
cld be the tps. its the 7afe
post Jan 13, 2013 - 4:57 PM
cajon
Joined Jul 22, '07
QUOTE (Box @ Jan 13, 2013 - 1:08 AM) *
MAF or MAP sensor?
k, thanks guys. Ill chk those sensrs, see wat hppns
post Jan 13, 2013 - 4:58 PM
Box
Joined Feb 23, '12
From Warrior, AL
7A-FE, should check the MAP sensor if you haven't already.
post Jan 13, 2013 - 6:23 PM
post Jan 13, 2013 - 6:39 PM
Box
Joined Feb 23, '12
From Warrior, AL
But yeah, hopefully that's it. Only like $30? or so for a new one.
post Jan 13, 2013 - 11:07 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
unplug the map and see if symptoms change. check hose for vac at the sensor.
Lo-Fi Version Time is now: November 29th, 2024 - 3:03 AM
