> Passenger side mount bolt question...
post Jan 13, 2013 - 3:23 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Long story short i'm missing the main two mount bolts that thread into the frame for the passenger side engine mount. I would like to know what length, size and thread pitch goes into them, or a place i can just buy them online would be great aswell.
94 ST 5spd 7A, thanks in advance folks.
Cleaning and improving my new found yoter little by little.
post Jan 13, 2013 - 10:06 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
the bolt is an M10X1.25 and any bolt thats about an inch long will do the job
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 14, 2013 - 7:39 PM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Appreciate it went and got them after work, if they wont thread (Pretty rusty don't think a chasser would work either) can i gain access through the wheel well to drill & tap a hole for new bolts and use a nut and washer? or is they're no way to get to those mounting points.
Guess i'll take a look see for myself this weekend.
post Jan 14, 2013 - 9:40 PM
travisxcore
Joined Mar 24, '11
From 704
Are the threads just worn? Or is it falling apart? You might try a tap and die set and see if you cant re-thread it.
post Jan 15, 2013 - 12:16 AM
Takumi-FujiWaraS...
Joined May 29, '12
From NC
Gave it a go.... the one toward the firewall started, but got to tight either it will strip or snap, the front is to far gone wont even start. Hoping i can drill and put a locking nut on the bolt from the bottom IF i can access them, if not idk threads are rusted and more or less pointless.
Lo-Fi Version Time is now: November 29th, 2024 - 8:26 AM
