> 1994 celica st205 gt4 wrc
post Jan 14, 2013 - 9:42 PM
bushaz110
Joined Jan 14, '13
From jayden110
Hey there fellaz as the topic title states, I have a 1994 toyota celica gt4 st205(Rhd). I want to tweak it a bit to maybe 300bhp and I would like to know what basic steps i need to take to have this done. I have an idea of what i want to have done and I will share it with you and you guys can advise me on if I am going in the right direction or what.
The list goes as follows:-
1) COMP TURBO CT3
2) CP PISTONS/ EAGLE RODS
3) CUSTOM UPGRADE INTERCOOLER
4) FUEL PRESSURE REGULATOR
5) TIAL 38MM WASTEGATE
6) WALBRO 255PSI FUEL PUMP
7) EXEDY STAGE 1 PERFORMANCE CLUTCH KIT
Currently the car need some work done in terms of overhauling. Gonna change the rings(which comes with the cp pistons) and also the valve seals.
Can you guys be so kind as to advise me on if I am going in the right direction with this setup.
The plan is to have a daily driven car, built reliably and can still go to the drag strip and have some fun without anything going wrong.
This post has been edited by bushaz110: Jan 14, 2013 - 9:48 PM
post Jan 15, 2013 - 1:24 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
you dont need pistons for that. the stock engine will support it easily. replacing the rings and honing the cylinders will suffice. since you are in there, i would also change the bearings. in fact everything on your list is not necessary
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: February 21st, 2025 - 6:42 AM
