> Steering Issues...., Turns to the right easy, left is a pain...
post Jan 15, 2013 - 4:44 PM
dabazied
Joined Jun 10, '07
From Riverside, CA
Hey guys. Been a while since I was on here but I have a question.
I'm trying to eliminate problems I'm having with my car. It has been raining bad for a week straight here so I haven't been able to look yet. My brakes need to be changed for sure.
On to the problem.... Today, I was driving and everything was fine except when trying to turn left. Left turns felt pretty difficult, but right turns are fine. I hear a little bit of metal noise, but the noise could be the brakes(which I planned on changing this weekend).
Any ideas on what is going on? I've never had an issue like this before.
She's Alive...... Again!!!
Sweet Jesus.
You rang?
Sorry, wrong number. :laugh:
post Jan 16, 2013 - 12:08 PM
dabazied
Joined Jun 10, '07
From Riverside, CA
Well, just got back to the car today and the caliper is grinding into the rotor.... Put the tire back on and was able to move it the wrong way.... Pretty sure my wheel bearing is bad....
Sweet Jesus.
You rang?
post Jan 16, 2013 - 1:54 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Move your tire the wrong way? What do you mean?
If you're wheel bearing i sbad, you'd hear a distinct "whirring" sound with the rotation of the wheel while driving, and will increase as you speed up. I've never had turning issues when my wheel bearings were bad.
My Celica!
post Jan 17, 2013 - 10:45 AM
dabazied
Joined Jun 10, '07
From Riverside, CA
The wrong way, as in grabbing the top and bottom of the tire and wiggling back and forth/up and down, however you want to put it. I haven't heard too much of a whirring sound, my engine is loud and my driver side window motor is broken.
I took it all apart, changed the wheel bearing(which was so bad and deteriorated I'm lucky the wheel didn't fall off) and now it is fine. The bad wheel bearing caused slack in how everything was sitting, causing the caliper to rub the rotor. It's all fixed now.
Sweet Jesus.
You rang?
Lo-Fi Version Time is now: November 29th, 2024 - 6:06 PM
