> help please
post Jan 16, 2013 - 3:17 PM
bessie1984
Joined Aug 29, '12
From nottinghamshire
ive got a huge oil leak on my gen 6 butim not sure what the part is lol it looks like a oil filter near the drivers front wheel at a angle n its leakin from there please help guys thanx matt
post Jan 16, 2013 - 3:31 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
There is a doughnut shaped oil cooler between the oil-filter and the engine block. My USDM 5sfe develoled a leak here and I had to replace the gasket. It cost <$10 for the gaskets, though I think I had to get them from Toyota. The oil could also be leaking from the seal on the oil filter itself, or from the valve cover gasket(oil has a way of sneaky-like dribbling down and appearing to come from somewhere else.
I think once the oil filter is removed the is a 10mm bolt near the top of the cooler on the exterior holding it on, and I believe the threaded center(the part the filter screws onto) somehow attached the entire assembly to the block.
post Jan 16, 2013 - 3:48 PM
bessie1984
Joined Aug 29, '12
its next to the oil pan i think it just looks like a normal oil filter sat at a angle its leaking from there
Lo-Fi Version Time is now: November 29th, 2024 - 10:41 AM
