Code 54 |
Code 54 |
Jan 20, 2013 - 12:00 PM |
Enthusiast Joined Sep 9, '08 From Jamaica Currently Offline Reputation: 1 (100%) |
Hey Guys,
Ive already solved this problem years ago, by both bridging the fluid level sensor, and by rewiring the pump plug, but now i have the CEL back and i cant remember for the life of me where i hid the pump wiring (the one i used resistors on)...can someone please show me with a pic or good explanation where the pump plug wud have been connected to the engine harness, i can follow it back to my hidden wires and redo what i need to. Thanks. Also, i got code 24 (Intake Air temperature sensor)....where is that located?? I have an ST-205 btw |
Jan 20, 2013 - 6:56 PM |
Hey Guys, Ive already solved this problem years ago, by both bridging the fluid level sensor, and by rewiring the pump plug, but now i have the CEL back and i cant remember for the life of me where i hid the pump wiring (the one i used resistors on)...can someone please show me with a pic or good explanation where the pump plug wud have been connected to the engine harness, i can follow it back to my hidden wires and redo what i need to. Thanks. Also, i got code 24 (Intake Air temperature sensor)....where is that located?? I have an ST-205 btw I found it, by the fuel pump relay box....still wanna know where the intake temp sensor is. |
Jan 20, 2013 - 9:09 PM |
i think its in the afm... look inside it should have a little thing poking into the airflow.. atleast its on my 3vz afm and my 1uz afm
Jan 21, 2013 - 1:31 PM |
Feb 24, 2013 - 2:57 PM |
I took out the only one i see (in the intake manifold) it looks good so i put it back, does anyone else have experience with a code 24.
Also, when u have a code 54, does it affect fuel pressure, i have 31psi on idle and think it should be more like 39. |
Feb 24, 2013 - 4:34 PM |
Enthusiast Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) |
Hi,
54, lower the boost, check the IC water level 24, just clear the ecu by pulling the EFI fuse and then check again for it, if it comes again you have a open or short sensor/wiring in the air box the 54 get also cleaned with the EFI fuse greetz This post has been edited by Sunny: Feb 24, 2013 - 4:34 PM -------------------- |
Lo-Fi Version | Time is now: November 29th, 2024 - 2:50 AM |
