Genuine Toyota GT-4 wheels for Celica ST |
Jan 26, 2013 - 5:59 PM |
Enthusiast Joined Oct 25, '10 From UK Currently Offline Reputation: 0 (0%) |
Hi all
I would like to fit genuine OEM Toyota alloy wheels to our 1997 Celica ST and would like to know what other Toyota models of this era share the same fitting and offset. Once I know I can then bother my local Toyota dealer for part numbers, prices and schematics from their Toyota EPC parts system. I'm finding it difficult to find out what wheels came on the GT and GT-4 models as standard? Any help, pics or suggestions greatly received. CK |
Jan 26, 2013 - 8:27 PM |
Celicas have a 5x100 lug pattern. Your cheapest and easiest bet would be 7th gen Celica GT-S or Scion tC rims. Check toyodiy.com for part numbers and general prices.
Jan 26, 2013 - 10:01 PM |
Enthusiast Joined May 4, '09 From coral springs florida US Currently Offline Reputation: 21 (100%) |
this is the original spec of the gt4 wheels
7½"x16" wheels, 215/50 VR 16 tires and you also use the wheels from the frs, wrx no STI's jettas wheels might work too. just make sure the hub is bigger than 54.1mm. or even better test them in your car before buying them. PS: if you are thinking to upgrade to gt4 calipers make sure you get the right wheels/ offset to clear the caliper. -------------------- |
Jan 27, 2013 - 2:31 PM |
All Toyota 5x100 wheels will fit. (on stock calipers)
Subaru wheels (some) will fit but will require some kind of hubcentric ring to seat properly. VW 5x100 wheels will fit, the same as above. EDIT: Had no time at the moment, but here's a list: 1. Celica 5th(5-lug) 2. Celica 6th 3. Celica 7th 4. Corolla 2003+ 5. Corolla XRS, Matrix XRS 6. Scion tC 7. Scion FR-S (they're making a lot of wheels 5x100 for it now) They are all 5x100, 54.1mm center bore. Subaru 1. WRX 5x100 are I believe 56.1mm center bore, and nobody makes a 2mm hubcentric spacer because it is just too small. You'd be better off boring the wheels to the next bore size that you can get a ring for. VW 1. MK4s and VR6 MK3 wheels fit. However they've got the same problem as the Subaru wheels, their center bore is 57.1mm, which is 3mm bigger than Toyota CB. Luckily though, there's 3mm aluminum hubcentric rings, and I believe 3mm is the smallest they come. LINK There's some Toyota wheels that look good, like Matrix XRS, Scion tC, Celica GT-S 00+, and Corolla XRS 07+ Corolla XRS 08 (Kinda look like Lexus IS300 wheels but in a 5x100 pattern, 17s) Scion tC RS version (18s) Matrix XRS 03-07; they're 17s Newer Matrix XRS 08+; I believe they're 17s This post has been edited by Syaoran: Jan 27, 2013 - 2:55 PM -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Jan 27, 2013 - 3:04 PM |
There's some cool VW wheels too, like the Jetta Wolfsburg Edition BBS RX (version2, they're 2-piece)
There's the Version 1s as well which I believe the GTI MK3 VR6 comes with them, they're both 16" There's the VW Long Beach which are 17" You could also always get spacer adapters, they're safe as long as they're hubcentric and are torqued down properly, and you have a ****load of options with 5x114.3 wheels (Mazda, Mitsubishi, Subaru, MR2, Camry, new Scion tC, Mazdaspeed, etc.) They go for 60-100 a pair. There's also the conversion of your hubs to 5x114.3 which has been done already, and only requires rear camry wheel bearing and hub assembly, rear camry discs, front rav4 wheel hub and celica bearing and front camry xv10 rotors, everything fits like it should (the discs fit even though they're from the camry) -------------------- 1993 Celica GT Coupe - sold
Jan 27, 2013 - 4:28 PM |
Enthusiast Joined Mar 1, '12 From iowa Currently Offline Reputation: 0 (0%) |
Sti does work but only the 04 model. 05 came in 5x114
Jan 27, 2013 - 5:11 PM |
Is the 2mm difference between the Celica bore (54.1) and a Subaru bore (56.1) that bad? I mean, would I really have to bore it out just so that I can use a hubcentric ring on them? I mean I shouldn't have any problems without using a ring, right?
I'm about to buy some in a week, that's why. |
Jan 27, 2013 - 5:44 PM |
get the ring
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 27, 2013 - 6:06 PM |
there are no rings for 54.1 to 56.1 though. i can't find a 2mm ring anywhere. the only place I did looked sketchy as hell.
edit: website here http://www.hubcentric-rings.com/size-56.1-54.1/ This post has been edited by mkernz22: Jan 27, 2013 - 6:07 PM |
Jan 27, 2013 - 6:33 PM |
maybe post on one of the stance related sites. they might have resources for this
Jan 28, 2013 - 3:20 PM |
There's some cool VW wheels too, like the Jetta Wolfsburg Edition BBS RX (version2, they're 2-piece) Those wheels look pitiful compared to other BBS types. This is the LM, '04 and '05 GLI. -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:40 AM |
