![]() Enthusiast ![]() ![]() ![]() Joined Oct 7, '09 Currently Offline Reputation: 8 (65%) ![]() |
hey everyone, quick question
will it effect my ride at all if i have 2 different size tires on my rims? i have 2 - 215/35/18s and 2 - 225/40/18s i was planning on running the 225/ 40s in the front and the 215/35s in the rear... can anyone think of anything that would go wrong from this as long as i keep the pairs matching like 2 in the front and 2 in the rear? thanks guys -------------------- NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold 1997 Celica ST- swapped and sold 2004 Ford explorer xlt 4x4- totaled 1997 Celica Convertible GT- Going Topless (; (18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi ( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 ) |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) ![]() |
Right now they're not of the same diameter.
if you're doing 215/35, then you need to either get 215/35, or 195/40, or 235/30. if you're doing 225/40, you need either 225/40, 205/45 or 245/35. -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) ![]() |
If you don't have AWD, having different tire sizes between front and back shouldn't affect you as long as you're going in a straight line. One axle simply has to spin faster than the other to make up the difference in distance covered per rotation.
However, you'll notice it in the handling. The 215/35 are 23.92 inches in diametre, close enough to stock to work. A 225/40 is 25.08 inches in diametre, well outside of what should be used to maintain speedometre accuracy and handling characteristics as designed. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
if what your aiming for is oversteer, i'd stick to the same size all round, buy 2 sports compound tyres for the front and 2 plastic tyres for the rear
-------------------- Mike W
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
dont do it, keep them all the same size
i just want to know why shouldn't i run it?
as long as the sizes match on the axles i don't see any ill effects happening? -------------------- NOVAKx17
putting those smaller ones at the back is dangerous, putting them at the front will make the car handle like ****.
thats the ill effects, but do whatever, its your car and your life. -------------------- Mike W
what makes it dangerous and handle like ****?
i'm not being an ass, i'm just trying to learn for my benifit... i've driven my eclipse with different sized tires like this and didn't notice a difference at all... -------------------- NOVAKx17
how goods your FF drifting skills?
not sure of the FF part. but drifting is okay . its alot more fun/easier in a rear wheel drive like my camaro rather then my celica. but i like drifiting. in the winter. i feel like this is going to be something just to make fun of me but go ahead and continue. -------------------- NOVAKx17
If you are using it for DDing, then I don't see the big deal. Just use the same two in the front and the same two in the back.
FF is front engine, front wheel drive. Delusionz is saying that putting the smaller tires on the rear will cause lots of unexpected oversteer.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) ![]() |
if anything have the larger (width) tires in the front.
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Okay.. thanks guys.
Yeah its just for daily driving and will only be used in the spring-fall. I was just wondering if they will wear funny -------------------- NOVAKx17
Lo-Fi Version | Time is now: February 22nd, 2025 - 8:05 AM |
