swap rear convertible windows from 1995 to 1997? |
Feb 2, 2013 - 4:06 PM |
Enthusiast Joined Jul 22, '12 From SouthEast Currently Offline Reputation: 0 (0%) |
Hi,
My rear windows do not role down. It may be wiring, I plan to investigate that this weekend. In the mean time, I found a 1997 celica convertible in pretty good shape. Do the rear windows swap on 1995 to 1997? On those windows, I heard there is a common problem with them, what is the part that normally breaks? Do rear tail lights swap? rear trunk? Anything else that is better on the 1997 that I should swap out? I want to swap the front clip but that is what is damaged on the 97. Thanks. |
Feb 2, 2013 - 11:03 PM |
The windows should be interchangeable and the tail lights can definitely be swapped out.
Lo-Fi Version | Time is now: January 10th, 2025 - 11:46 AM |
