7AFE, ENGINE ISSUES |
Jan 20, 2004 - 8:43 AM |
ok so i think i've gathered from this whole forum that the least favored engine of all our cars is the 7-afe but hey most of us are stuck with it. So i've looked around and checked in most post for what everyone has suggested meaning: turbo, nitrous oxide, engine swaps. But turbos for this engine are not only hard to piece together but cause alot of issues. Now what i'm asking for is before we turbo and nos we need internals right? cams, rods, pistons, heads redone...ect. but these are hard to find from what i've looked. maybe its just me and i'm really crappy at looking for parts. soo to make this short if you know where to find cams for a 7 put up a link. if you know where to find FORGED pistons, post a link or light weight and stronger rods....you know the deal by now THANKS guys and girls for the few of you out there
Jan 20, 2004 - 9:02 AM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
There are few things that need to be done before you put turbo on your 7A. First - pistons. if you have $$$ get forged Arias or other pistons. I you low on cash, then you can get 4A-GZE pistons (thay fit, with little mods). Second step is rods, they are pricey cuz you have to make them custom... about 700$. About cams, as long as i know, there are NO cams availible for 7A exept custom made... so no info on this... About redoing your head... If you aint aiming for crazy Hp number it is not nessesary. Just macth all the ports, and clean your intake manifold. -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Jan 22, 2004 - 1:31 PM |
Enthusiast Joined Jan 22, '04 From bellingham, WA Currently Offline Reputation: 0 (0%) |
get latermodel 4a-gze pistons from a JDM redtop 4a-gze... has a slightly lower compression ratio of i believe 8.0:1....
or you can get JE pistons as well.... those are generally good for about up to 30psi (according to some corolla owners on vvti). you could also think about swapping in an entire 4a-gze.... it comes supercharged and has a stronger crank..... you can easily swap over to turbo or if you want, twin charge the motor |
Jan 22, 2004 - 6:27 PM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
stock 7afe cams work well for mild turbo applications.
after that you need a cam re grind. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Jan 22, 2004 - 6:36 PM |
Enthusiast Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
the "problem" as you so call it. with the 7AFE is a weak crankshaft, this is supposedly the first thing to get weak if you have a correct, well built race motor. which they also do not have readily available. basically the 2 toyota 4-cylinder motors that have the most readily available parts made for it are versions of the 3S motor, and the 4A motor.
-------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Jan 23, 2004 - 1:12 AM |
the 300 horse 7age 20v that was posted up recently used a stock 7a crank. I don't know how long it lasted though...
Jan 23, 2004 - 2:14 AM |
I'm sure the 7A crank can take 300hp n/a...but I dunno about forced induction. That's 2 different worlds in terms of internal stress on engine components... -------------------- "It's ok to be naked girl... I'm an artist!"
Jan 23, 2004 - 1:35 PM |
Enthusiast Joined Aug 29, '02 From Dallas, Tx Currently Offline Reputation: 0 (0%) |
Huh? The stresses are slightly different but not enough to really have to worry about it. How are you so sure that it can take 300hp n/a? |
Jan 23, 2004 - 2:05 PM |
are your tranny's actually holding up? last i heard, the c50/c52 transmissions were only good for up to around 200hp..... i'm guessing a 4a-gze e51 (from japan) transmission could probably hold more....
Jan 23, 2004 - 4:20 PM |
Enthusiast Joined Aug 29, '02 From San Diego CA Currently Offline Reputation: 0 (0%) |
I'll put all your worrys to rest in less then a year. ill probably be the only person thats going to get his 7A motor and do a complete NA application on it. ill post numbers and what i did when im done with it.
Jan 23, 2004 - 5:47 PM |
I'm guessing there will be a lot more stress with forced induction than n/a, simply because in order to build around 300hp n/a... you're mostly gonna have to revv more (with appropriate upgrades in the head). That will stress the internals, but higher-revving, IMO, will affect crank balance more than actual forced stress. Forced induction, will actually strain the crank more, although revving less, it will create a lot more stress via boosted intake. Why? Consider torque... A 300hp n/a motor will make much less torque than a 300hp turbo... That's mostly my speculation... call it an educated guess... This post has been edited by Kwanza26: Jan 23, 2004 - 5:47 PM -------------------- "It's ok to be naked girl... I'm an artist!"
Jan 23, 2004 - 6:27 PM |
racer25 on corolla-racing.com has built his 7a-fe pretty well for NA purposes.... although he's getting ready for some sort of hybrid (probably a 20V 7a-ge with silvertop head), the numbers he's gotten are decent.... some of the things i know he's done (and he has done more than this as well)... rebuilt motor auto -> 5 speed swap (using an ae92 GTS c52 transmission) tuned ecu, removed rev limiter (i think he said the valves start to float at around 7500 rpm's or so) 4a-fe pistons (for higher compression) thinner head gasket (for higher compression) underdrive pulleys sard adjustable FPR supra (the green one) fuel pump i *think* he's using either 5s-fe or 4a-ge injectors as well I/H/E limited slip diff. and he ran some decent numbers... i want to say it was a low 16 sec or so... maybe high 15, i don't remember..... (same guy also has a te27 that he's shooting for 200RWHP in a 2,000lb car) |
Jan 23, 2004 - 6:39 PM |
Enthusiast Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
All that money spent on 7AFE and hybrid applications and a Civic with an H22 swap will still eat it. People gotta balance things out before starting to throw money and time away.
Jan 23, 2004 - 7:05 PM |
how has he thrown money out? he gets parts from pull-a-part junkyards and does all the work himself...... the only thing that he won't use on the hybrid is the 7a-fe engine specific parts.... he was originally going to turbo it though.... i think that changed when he decided to turbo the te27....
also, a civic with an H22 won't outrun a corolla through corners.... it's way too front heavy and will want to swap ends easily... along with that, the H22a's are fairly expensive and the swap isn't easy per say..... |
Jan 23, 2004 - 7:15 PM |
You kinda contradict yourself in here but you're almost on the right track. The n/a motor will have to rev more to make the same power, it might not make less torque, but it will not make it at the lower rpm. Reving higher will greatly increase the stresses in the motor as will the slightly greater cylinder pressures created because of the necessary increase in volumetric efficiency (making the engine breathe better). The turbo engine will have much higher cylinder pressures due to the extra air and fuel entering the cylinders but it will not have to rev nearly as high to make the same power. Because of the way the cam and ignition timing works out, the higher cylinder pressures at lower rpm will actually help to decrease the stresses on the rods, although the crank and its bearings will still see higher stresses. To make a really long story really short, for the same power level its much easier on an engine to be turboed than to have to rev higher without the turbo. That being said, the turbo motor will still have higher stresses than the stock motor. Its almost going to be impossible to make an n/a 7a put out 300hp. Its going to have to rev very very high and the only 'stock' part that will be left is the block. Its definitely possible to make a 300hp 7a with a turbo. I think its even possible with a stock block, crank, cams, and head (ported). But thats just my oppinion and will remain so until I come up with the funds to prove it. |
Jan 23, 2004 - 7:20 PM |
pretty much any honda swap is plug and play. its like messing around with legos.
still 16-15s after that many hours working on a motor? seems kinda pointless IMO even if its not a strip car or anything... thats still pretty slow. -------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Jan 23, 2004 - 8:01 PM |
kind of... B series motors are like legos yes... but the H22 is different.... requires diff tranny and mounts, diff motor mounts, you have to pound back the firewall, and it barely fits into a civic...... and the h22a isn't a cheap motor.... probably at least 2x the price of a blacktop 20V and also, it is a daily driver.... he does have bigger plans for it, but the car is a hobby, so the "time wasted" really isn't time wasted...... and to let you know, my car runs a 17.33 in the 1/4 mile... yes it's WAY slow... but i can keep up with (if not beat) about 1/2 of the cars that auto-x around here.... how fast a car is in a straight line isn't everything..... and 99% of those cars that auto-x could kill me in a 1/4 mile race |
Jan 23, 2004 - 11:35 PM |
Ok mister, you don't have to defend him a lot...don't get to defensive. I didn't post that to argue, it's a real possibility. -------------------- |
Jan 23, 2004 - 11:51 PM |
weve gotten way offtopic. all im trying to say is even though the setup is kool and was cheap, the gains are less than impressive. i feel if it is a car setup for autoxing, that money could have been better spent in the suspension and tires. all that stuff most likely would put him into a SM class, where cars are much more modified.
Jan 25, 2004 - 5:21 AM |
i'll just put it as his 7a-fe pulls just like a 4a-ge smallport..... if you can keep it n/a and do that, it's well worth it..... and i'm defending him a bit because he's a friend of mine and he will be helping me out more than i could pay him back for
Lo-Fi Version | Time is now: November 28th, 2024 - 10:32 PM |
