> Beams Alternator Done did it,....!, if you did the swap, please help
post Feb 5, 2013 - 2:12 PM
So i found the reason my battery was not charging, or dying. Turns out the Alt is not charging full output. That means, new alt or fox this one.
If you did a swap and still have the old 5sfe alt, please see if your connector is the same for the alt. As I was very dumb and already sold the Alt.
Before I embark to get a new one, id like to know if it would be a straight thing. I rather have this as a post, so that the information is shared.
post Feb 5, 2013 - 2:28 PM
richee3
Joined Jun 29, '08
From Denver
The plug is the same but it's in a different location. You can get your alt rebuilt pretty cheap, there should be somebody close that does it. I've still got to figure out whether my alt fried my battery or my battery died and my alt is overcharging to compensate.
Edit: I might be thinking of my Greytop alt I ran for a while. First Redtop alt was dead, used a Greytop alt with the same plug but in a different spot, then got the second Redtop and am using that alt. I'm still pretty sure that the 5S uses the same plug but don't quote me on that.
This post has been edited by richee3: Feb 5, 2013 - 2:31 PM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 5, 2013 - 2:29 PM
I took my car to oreilly, what do u mean its in a different location? different plug? or ? huh
thinking of getting a high output alt.
post Feb 5, 2013 - 2:33 PM
richee3
Joined Jun 29, '08
From Denver
The plug was the same, but it was in a different spot on the alternator. I don't think I have pictures of that alt, I'd have to check my computer.
1998 Celica GT-
BEAMS Swapped.
post Feb 5, 2013 - 2:37 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
all 3sge are 80 amp
5sfe automatic is 80 amp
5sfe manual 70 amp
3sgte is 90 amp
post Feb 5, 2013 - 2:52 PM
richee3
Joined Jun 29, '08
From Denver
Greytop alt:
Redtop alt:
The plug is in the same place, but the single wire is in a different spot. 5S alt, I believe, has the same plug. I had a 5S alt and BEAMS alt laying in my garage for a while and couldn't tell them apart until I put them on the engine. Had to use the wiring harness length to figure out which alt was which.
This post has been edited by richee3: Feb 5, 2013 - 2:53 PM
1998 Celica GT-
BEAMS Swapped.
post Feb 5, 2013 - 3:02 PM
I see it now, borrowed some pics from the engine thread.
post Feb 5, 2013 - 3:09 PM
I may have to extend the harness. No biggy!
well u can rebuild the alts
http://rebuilderinabox.com/contact-us/
http://www.youtube.com/watch?v=CImyX5KuGvQ
but id rather get it new.
post Feb 6, 2013 - 1:14 AM
azian_advanced
Joined Apr 18, '05
From Calgary
why not replace the brushes (assuming the shaft is still in good working order)? they're usually the part that wears out first inside the alternator, only cost $15 from the dealer, replacing it is almost fool-proof and only takes a few minutes. this part number should help: 27370‑75060.
post Feb 11, 2013 - 9:05 PM
Dangercart1
Joined Dec 8, '09
You can use the 80 amp from a auto 5sfe you just have to drill out the threaded hole, i did that on mine and I've been running fine since september
post Feb 11, 2013 - 9:25 PM
well i ordered the piece, and decided to give it a try, if not im headed that way. I spend 10 bucks, if that works, i rather go that way
post Feb 13, 2013 - 6:01 PM
did it today, and had it rechecked, and it works.. thanks.
post Feb 17, 2013 - 1:25 PM
richee3
Joined Jun 29, '08
From Denver
False alarm for me, it was just a bad battery. Turns out the alt was just doing it's job and trying to keep everything running when the battery couldn't.
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: November 30th, 2024 - 12:37 AM
