> How to debadge
post Jan 20, 2004 - 1:20 PM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
I started to debadge my toyota text on the rear with a heat gun and i cant get all the glue off. Is there some trick to this? I have most of it off, but there is still an outline of the work toyota (it looks like ****). I have a heat gun and have been heating it up and rubbing on the glue but it wont come off any more.
thanks for any help
-Stew
post Jan 20, 2004 - 4:24 PM
Guest_Jason_*
The greatest solution: Lighter Fluid
Don't let it soak in for more than 5 seconds else it could begin to fade your paint. As long as you soak the glue and rub at it, it will come off cleanly and flawless (with no paint damage), but it only fades paint if left on for a decent amount of time.
post Jan 20, 2004 - 4:36 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
bug and tar remover. or goo gone its adhesive remover.
LatinKraze
Joined Oct 22, '03
Does gasoline work?
post Jan 20, 2004 - 5:07 PM
Sh0gunkid8721
Joined Feb 22, '03
i took off my pinstripes and im havin the same problems...thats why im afraid to debadge and Bug and Tar remover is NOT workin for me either
post Jan 20, 2004 - 5:26 PM
ghostdog
From ny to philly
QUOTE (LatinKraze @ Jan 20, 2004 - 4:36 PM)
Does gasoline work?
don't use gasoline, it will fade your paint fast. rubbing alchohol works fine on the adhesive and won't damage your paint if you're careful with it.
post Jan 20, 2004 - 5:31 PM
LatinKraze
Joined Oct 22, '03
I sortta noticed the rag was a lil red. I shouldda waited to read ur post. Lol
post Jan 20, 2004 - 7:53 PM
RedSunCelica
From San Diego CA
dental floss or using theard of string to remove the emblems.
Then go to wall mart or auto zone and pick up some stuff called "Goo Gone" its paint friendly and take the stuff off easily.
or if you want to get really original and get half a orange, and rub it where the glue is at wait a few seconds then with your credit card edge just gently remove the glue. biggrin.gif
post Jan 20, 2004 - 10:25 PM
Cragspider
Joined Aug 30, '02
From Franklin,Tn
Use a hair dryer to heat the glue up so that you can just pull them right off.
Bryan
post Jan 20, 2004 - 10:40 PM
i just pulled them off, then used googone and kept rubbing it for a while till it was all gone.
post Jan 21, 2004 - 8:38 AM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
i just tryed goo gone and there is still a little outline of where it was. do you think it might just be years of wax and dirt that have built up there? and if yes the could i just buff and polish it out?
EDIT- I just tryed rubbing alchohol and it worked great. thanks for everyones help
-Stew
This post has been edited by BEEFSTEW800: Jan 21, 2004 - 6:37 PM
Lo-Fi Version Time is now: December 4th, 2024 - 12:51 AM
